655
Change Tooltip CSS
Is it possible to change the style of tooltips for individual items in the web drop down?  All of our controls use a javascript function to display their tooltips because the standard tooltips do not display long enough.  These tooltips are styled by a tooltips.css file and I would like the tooltips for the items in the dropdown to be the same.  Below is an example of how we handle the tooltips for a standard text box.
<asp:TextBox ID="txtBatchNo" runat="server" CssClass="TextBoxes" onmouseout="hideTooltip()"onmouseover="showTooltip(event,'The batch or lot number of the product (on the label).');return false"MaxLength="35"></asp:TextBox>
And this is how I currently setup the WebDropDown.
ig:WebDropDown ID="ddTreatmentRoute" runat="server" DropDownAnimationType="Linear" DropDownContainerHeight="0px" DropDownContainerMaxHeight="0px" DropDownContainerWidth="0px"EnableDropDownAsChild="True" MultipleSelectionType="Checkbox" PageSize="0" StyleSetName="Office2007Blue" EnableRenderingAnchors="False" DisplayMode="DropDownList" ToolTip="Initial Tooltip for overall control.">
<Items>
<ig:DropDownItem Selected="False" Text="Please select" Value="0">
</ig:DropDownItem>
<ig:DropDownItem Selected="False" Text="Auricular use" Value="1" ToolTip="Item 1 tooltip">
</ig:DropDownItem>
<ig:DropDownItem Selected="False" Text="Cutaneous use" Value="2" ToolTip="Item 2 tooltip.">
</ig:DropDownItem>
<ig:DropDownItem Selected="False" Text="In-feed use" Value="3" ToolTip="Item 3 tooltip.">
</ig:DropDownItem>
</Items>
<Button AltText="" />
</ig:WebDropDown>
</ig:WebDropDown>
Luke
  • 695
    Verified Answer
    Hello Luke,
    there are ItemMouseOver and ItemMouseOut client-side events, which you can use for adding a custom javascript function for displaying a tooltip.
      function ItemMouseOver (sender, eventArgs) {
                 var item = eventArgs.get_value(); // gets a reference of a DropDownItem
                 var value = item.get_value(); // gets the item's value
                 //your custom tooltip code
        function ItemMouseOut (sender, eventArgs) {
    </script>
     <ig:WebDropDown ID="ddTreatmentRoute" runat="server" DropDownAnimationType="Linear" Width="200px"
                <ClientEvents ItemMouseOver="ItemMouseOver" ItemMouseOut="ItemMouseOut" />
                <Items>
                    </ig:DropDownItem>
                    </ig:DropDownItem>
                    </ig:DropDownItem>
                    </ig:DropDownItem>
                </Items>
            </ig:WebDropDown>
    Nikolai Dimitrov
