I've been attempting to implement a custom paging control for my WHDG using the following two sources:
http://community.infragistics.com/aspnet/articles/learn-to-build-a-webdatagrid-custom-pager.aspx
http://samples.infragistics.com/2010.2/WebFeatureBrowser/contents.aspx?showCode=true&t=WebDataGrid/Paging/WebDataGrid_AdvCustomPager.aspx~srcview.aspx?path=~srcview.aspx?path=WebDataGrid/Paging/WebDataGrid_AdvCustomPager.src
But with both i run into the same issue, I am unable to obtain a reference to the paging control.
I place the ascx user control into page by dropping it in the designer, then move the code to the behavior section of the WHDG
<Behaviors> <ig:Paging PageSize="100"> <PagerTemplate> <uc1:CustomPager ID="CustomPager" runat="server" /> </PagerTemplate> </ig:Paging> </Behaviors>
Then try to get a reference to the object with:
this._customPager = this.Report_Grid.Behaviors.Paging.PagerTemplateContainer.FindControl("CustomPager") as CustomPager;
I've tried in multiple places to get a reference, WHDG init, page_load, Page_init, etc. ReWrote the code about 3 times, tripple checked my control names, tried PagerTemplateContainerBottom, PagerTemplateContainerTop, PagerTemplateContainer.
No matter what i try the findcontrol always returns null.
Ahh, that works, this.Report_Grid.GridView.Behaviors.Paging.PagerTemplateContainerBottom.FindControl("CustomPager") as CustomPager;
Successfully returned my custom pager.
Thanks.
Could you try doing your find off of this.Report_Grid.GridView.Behaviors.Paging?
regards,David Young
