20
"Object reference not set..." when clicking on row in an async postback
Hi all,
I'm using a WebHierarchicalDataGrid in NetAdvantage 2010.2.  When I click on a row, I can get to a server-side method using the AutoPostBackFlags feature.  But I continuously get the following when I click on a child-row:
NullReferenceException: Object reference not set to an instance of an object.]
The full stack trace is:
[NullReferenceException: Object reference not set to an instance of an object.]
Infragistics.Web.UI.Framework.RunBot.RenderPageCallBack(HtmlTextWriter writer, Control control) +50
System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +256
System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +19
System.Web.UI.Page.Render(HtmlTextWriter writer) +29
System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27
System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +99
System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1266
Because I've gone back and forth with this, I made a real simple page to display this issue.  I'd like to use this control but it's a hard sell when I can't react to a click on the server side.  Can anyone help me with this?
Bill
Here is the aspx page:
@ Page Language="C#" AutoEventWireup="true" CodeBehind="TestGridRowClick.aspx.cs" Inherits="testProject.TestGridRowClick" %>
DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
html xmlns="http://www.w3.org/1999/xhtml" >
head runat="server">
<title>Untitled Page</title>
head>
body>
<form id="form1" runat="server">
<asp:ScriptManager ID="ScriptManager1" runat="server">
</asp:ScriptManager>
<div>
<ig:WebHierarchicalDataGrid ID="whdg1" runat="server" DataSourceID=""
AutoGenerateColumns="false" AutoGenerateBands="false" InitialExpandDepth="0"
InitialDataBindDepth="-1" Height="350" Width="100%" DataKeyFields="ID"
ExpandableAreaCssClass="ighg_FeatureBrowserExpandableArea" EnableViewState="true" EnableAjax="true" EnableAjaxViewState="true"
MaxDataBindDepth="5"
OnRowSelectionChanged="whdg1_RowSelectionChanged"
<ExpandCollapseAnimation SlideOpenDirection="Auto" SlideOpenDuration="0" SlideCloseDirection="Auto"
SlideCloseDuration="0" />
<Columns>
<ig:BoundDataField DataFieldName="SubordinateItem" Key="SubordinateItem" Header-Text="Item" Width="10%"/>
<ig:BoundDataField DataFieldName="SubordinateName" Key="SubordinateName" Header-Text="Item Name" Width="90%" />
</Columns>
<Behaviors>
<ig:VirtualScrolling Enabled="true" RowCacheFactor=".5" ScrollingMode="Deferred"></ig:VirtualScrolling>
<ig:Selection Enabled="true" CellClickAction="Row" RowSelectType="Single">
<AutoPostBackFlags RowSelectionChanged="true" />
</ig:Selection>
</Behaviors>
<Bands>
<ig:Band DataMember="itemRollupSource_DefaultView" Key="ID" ShowHeader="true"
ShowFooter="false" IsSelfReference="true" AutoGenerateColumns="false" >
<Columns>
</Columns>
</ig:Band>
</Bands>
</ig:WebHierarchicalDataGrid>
<ig:WebHierarchicalDataSource ID="itemRollupSource" runat="server">
<DataRelations>
<ig:DataRelation ChildColumns="SubordinateParentItem" ChildDataViewID="itemRollupSource_DefaultView"
ParentColumns="SubordinateItem" ParentDataViewID="itemRollupSource_DefaultView" />
</DataRelations>
<DataViews>
<ig:DataView ID="itemRollupSource_DefaultView" />
</DataViews>
</ig:WebHierarchicalDataSource>
</div>
</form>
body>
html>
Here is my code-behind:
using
System;
using
System.Collections;
using
System.Configuration;
using
System.Data;
using
System.Linq;
using
System.Web;
using
System.Web.Security;
using
System.Web.UI;
using
System.Web.UI.HtmlControls;
using
System.Web.UI.WebControls;
using
System.Web.UI.WebControls.WebParts;
using
System.Xml.Linq;
using
System.Collections.Generic;
namespace
testProject
public partial class TestGridRowClick : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
protected void Page_Init(object sender, EventArgs e)
BindGrid();
protected List<myHierarchy> _getSampleData()
List<myHierarchy> resultList = new List<myHierarchy>();
resultList.Add(
new myHierarchy(){ID=1, TopLevelItem="x", SubordinateParentItem=null, SubordinateItem="x", SubordinateName="X Name"});
resultList.Add(
new myHierarchy() { ID = 2, TopLevelItem = "x", SubordinateParentItem = "x", SubordinateItem = "x1", SubordinateName = "X1 Child Name" });
resultList.Add(
new myHierarchy() { ID = 3, TopLevelItem = "x", SubordinateParentItem = "x", SubordinateItem = "x2", SubordinateName = "X2 Child Name" });
resultList.Add(
new myHierarchy() { ID = 4, TopLevelItem = "x", SubordinateParentItem = "x", SubordinateItem = "x3", SubordinateName = "X3 Child Name" });
resultList.Add(
new myHierarchy() { ID = 5, TopLevelItem = "x", SubordinateParentItem = "x3", SubordinateItem = "x31", SubordinateName = "X31 Child Name" });
return resultList;
public void BindGrid()
string currentItem = "x";
List<myHierarchy> listResult = _getSampleData();
Infragistics.Web.UI.DataSourceControls.
DataView view = itemRollupSource.DataViews.FindByID("itemRollupSource_DefaultView");
if (view == null)
view =
new Infragistics.Web.UI.DataSourceControls.DataView();
view.ID =
"itemRollupSource_DefaultView";
itemRollupSource.DataViews.Add(view);
view.DataSource = listResult;
whdg1.DataSourceID =
"itemRollupSource";
protected void whdg1_RowSelectionChanged(object sender, Infragistics.Web.UI.GridControls.SelectedRowEventArgs e)
SelectedRowCollection src = e.CurrentSelectedRows;
if (src.Count > 0)
string itemSelected = src[0].Items[0].Text;
// fill another grid
public class myHierarchy
public int ID {get; set;}
public string TopLevelItem {get; set;}
public string SubordinateParentItem {get; set;}
public string SubordinateItem {get; set;}
public string SubordinateName {get; set;}
