220
Installation ended prematurely because of an error with 2007 vol. 1 on Windows 7 64-bit
I am trying to run Net Advantage 2007 vol. 1 installer on Windows 7 64-bit. I am running the installer with the "As an Adminsitrator" option. My own domain account is in the Local Admins group of my PC. The UAC feature of Windows is turned off. Also the IIS is activated as a Windows feature and IIS6 compatibility is turned on too.
The problem is that the installation does not finish properly:
1. First, I got an error with the unresolved "SystemDrive". I resolved that modifying my registry keys. I found the solution here: http://forums.infragistics.com/forums/p/8328/33067.aspx#33067
2. Then the instalation ran almost to its end, but the rolled back with an error message in the end stating "Installation ended prematurely because of an error". I cannot find any solution and cannot instal.
Thanx for help.
