I have a webdatagrid bound to a SQLDataSource. Table looks like below
ControlNum SubNum MyDate
20100617.02 1 06/25/2010
20100617.02 2 06/30/2010
20100617.02 3 07/14/2010
20100617.02 4 06/08/2010
When I want to delete a row (for example row with SubNum=2), I can delete fine and everything works great. Now the number of rows left in the table is three (SubNums: 1, 3, and 4 are left)
Right after I delete I would like to edit the rest of the SubNums so that the row where Subnum =3 is changed to =2. and row where SubNum=4 is now =3. The Grid then should look like this:
20100617.02 2 07/14/2010
20100617.02 3 06/08/2010
I would like to do this in Javascript. I have come up with the below code but for some reason after I delete the row and try to change the Subnum it will give me error "this._props is null or not an object"
script type="text/javascript"
var selectedDataKey = "";
var changed = false;
function onRowSelectionChanged(sender, eventArgs) {
var rows = eventArgs.getSelectedRows();
var selectedRow = rows.getItem(0);
selectedDataKey = selectedRow.get_dataKey();
function DeleteCorr() {
var answ = confirm("Are you sure you want to delete this correspondence?")
if (answ) {
if (selectedDataKey != "") {
var grid = $find("<%= wdgSubmission.ClientID %>");
var rows = grid.get_rows();
var row = rows.get_rowFromKey(selectedDataKey);
var subnum = row.get_cell(1).get_value();
var sub = subnum-=1
var rowl = rows.get_length();
rows.remove(row, false
if (subnum < rowl) {
for (var x = sub; x <= rowl - 1; ++x) {
var cgrid = $find("<%= wdgSubmission.ClientID %>");
var crows = cgrid.get_rows();
var crow = crows.get_row(x+1);
crow.get_cell(1).set_value(x+1);
else
alert("
Please select a row to remove.");
else {
script>
Thanks!
Kavita Patel
