Hi I want to change the column width of child rows
1) I can achieve this using manual load on demand but problem is sorting is not working ,also I need to filter by key and then bind.
since I am using same db , I can populate the relation in dataset and bind. so I prefer automatic load on demand.
now i want to change the column width of the child rows.
if any one knows please help me out.......
guys Some how I make it work.
AutoGenerateBands = true --- this is for automatically generating the bands.
below is for enabling the sort.
<ig:Sorting Enabled="true" EnableInheritance="true">
</ig:Sorting>
</Behaviors>
below is for controling the column properties.
Private Sub whdgSearch_RowIslandCreated(ByVal sender As Object, ByVal e As Infragistics.Web.UI.GridControls.RowIslandEventArgs) Handles whdgSearch.RowIslandCreated
e.RowIsland.AutoGenerateColumns = False
Dim column1 As BoundDataField = New BoundDataField()
column1.DataFieldName = "ContactName"
column1.Key = "ContactName"
column1.Header.Text = "System"
column1.CssClass = "clsTextLeft"
column1.Header.CssClass = "clsColumnHeader"
column1.Width = New WebControls.Unit(100, UnitType.Pixel)
Dim column2 As BoundDataField = New BoundDataField()
column2.DataFieldName = "ContactTitle"
column2.Key = "ContactTitle"
column2.Header.Text = "Title"
column2.CssClass = "clsTextLeft"
column2.Header.CssClass = "clsColumnHeader"
column2.Width = New WebControls.Unit(200, UnitType.Pixel)
e.RowIsland.Columns.Add(column1)
e.RowIsland.Columns.Add(column2)
End Sub
Thanks for the response,
I can't give the columns in markup because my columns are not fixed.
if I am giving in codebehind in code behind , I am having problem in sorting.
how to set the width of column for child bands in client side? can you provide me sample or specify the method to do.
thanks in advance
If you are setting up your columns in the markup, you can simply set the width of the columns on the child Band. Same goes for if you add your columns in the code-behind. If you are having the columns autogenerated, then you cannot access them in the code-behind. You could access them on the client and change widths there, though. If you still have trouble, could you attach your aspx and code-behind?
regards,
David Young
