177
Create ig_res virtual directory in Sharepoint 2010 IIS Tree
Urgend
Under default web sites we have after installing NetAdvantage ASP.NET 2010.2 an virtual directory ig_common. A custom website with Webgrid or HierarchicalGrid search in the ig_res folder.
I will use Hierarchical or normal WebGrid in Visual Web Part in Sharepoint 2010. How can i create an own ig_res under Sharepoint Web Site Directory under Inetpub\wwwroot same in the default web sites.
I already create an Application named ig_res same as in default web sites (ig_common) in IIS and show to the physical directory Inetpub\wwwroot\aspnet_clients\infragistics\20101CLR35\styles.
But this is not enough I think. Some Styles I can see in my visual web part, but some not. Also Scripts the Grid needed.
How can I build this for wwwroot for Sharepoint 2010. This is an urgend question, please!
