Hi Team,
There is an issue occurring in the grid when opening in IE. The issue is that the first row is showing with wrapped text in Internet Explorer. And the property Autogeneratecolumns is set to true. The same is there even the property is set to false. I need to implement with both the property values. How could i overcome this compatibility issue.
Thanks & Regards,
Assyst
Forgot to say i am referring to first row not to header row.
Thanks & regards,
According to Alexander Kartavov from Infragistics : -
"this is a bug in the browser, so it's out of our hands to fix that particular glitch".
So i think there is no need to reproduce it as the issue is already reported to Infragistics by many users. And i got a solution in reply as this.
Anyway i am glad to say that recently i fixed this particular glitch.
I am following up one more time to see if you're able to provide a workable sample on reproducing this behavior or if you could include additional details so that I can reproduce on my side. I can then look into this further. Thank you.
Sincerely,Duane HoytDeveloper Support EngineerInfragisticshttp://ko.infragistics.com/support
Also if you could provide css that was used for the grid. Was it created using custom css or the default css provided by the control by default. I can also create a workable sample demonstrating this behavior.
Let me know which you would prefer.
Sincerely,Duane
Is the first row that you're referring to the header of the grid or the first row of the data? Also please send the aspx markup and any screenshots that is showing as wrapped text. Thank you.
