210
Problems dynamically adding bands to WHDG
Hi all,
I've been stuck for a while trying to setup our WHDG. We have a dynamic, changing, dataset object coming back from our databases. This can have N relationships and tables in it. We must create the bands manually so that we can hide columns and format the display.
Note: If I set the grid to auto create the bands, it works fine but the display is no good for our needs.
However, if I try to create a band for each dataTable in the set then the 2nd level + band I create are not used.
Also, if I create the bands manually but leave AutoGenerateBands="True" then the 2nd level band has no formatting.
Is there some way I can view the auto generated bands in code? If so then maybe I could see what was wrong with my setup.
This is the function I used to setup the bands:
Protected Overrides Sub OnInit(ByVal e As EventArgs)
Dim i As Integer = 1 ' skip root band/table (this is already setup in the grid)
        While i < Me.WHDG1.DataSource.Tables.Count
            Dim band As New Infragistics.Web.UI.GridControls.Band
            Dim table As New DataTable
            table = Me.WHDG1.DataSource.Tables(i)
            Me.WHDG1.Bands.Add(band)
            band.DataMember = table.TableName
            band.Key = table.TableName
            band.DataKeyFields = "Autoid"
            band.ShowHeader = False
            band.AutoGenerateColumns = False
            addDataField("Sel", "Sel", "20", False, "columnClassSel", table, band)
            addDataField("Sel1", "Sel", "20", False, "columnClassSel", table, band)
            addDataField("Sel2", "Sel", "20", False, "columnClassSel", table, band)
            addDataField("Sel3", "Sel", "20", False, "columnClassSel", table, band)
            addDataField("Sel4", "Sel", "20", False, "columnClassSel", table, band)
            addDataField("Sel5", "Sel", "20", False, "columnClassSel", table, band)
            addDataField("Sel6", "Sel", "20", False, "columnClassSel", table, band)
            addDataField("display", "display", "", False, "", table, band)
            addDataField("Available", "Available", "70", False, "columnClassAvailable", table, band)
            addDataField("name", "name", "", True, "", table, band)
            addDataField("parenttable", "parenttable", "", True, "", table, band)
            addDataField("parentkey", "parentkey", "", True, "", table, band)
            addDataField("childtable", "childtable", "", True, "", table, band)
            addDataField("level", "level", "", True, "", table, band)
            addDataField("filter", "filter", "", True, "", table, band)
            addDataField("incex", "incex", "", True, "", table, band)
            addDataField("tbl", "tbl", "", True, "", table, band)
            addDataField("bandkey", "bandkey", "", True, "", table, band)
            i = i + 1
        End While
 Private Sub addDataField(ByVal fieldName As String, ByVal key As String, ByVal width As String, ByVal hidden As Boolean, ByVal cssClass As String, ByRef table As DataTable, ByRef band As Infragistics.Web.UI.GridControls.Band)
        If table.Columns.Contains(fieldName) Then
            Dim dataField As Infragistics.Web.UI.GridControls.BoundDataField = New Infragistics.Web.UI.GridControls.BoundDataField
            dataField.DataFieldName = fieldName
            dataField.Key = fieldName
            dataField.Hidden = hidden
            dataField.CssClass = cssClass
            If Not width = "" Then
                dataField.Width = width
            End If
            band.Columns.Add(dataField)
        End If
    End Sub
