I have my webtabs set to.
PostBackOptions EnableAjax="True" EnableLoadOnDemand="True" />
and the SelectedIndexChanged event fires the first time i click each tab, but it never fires after the first click, so if I go back to the first tab or a tab I have click it doesn't fire. How can I make it fire ever time the tab is clicked?
You don't have the right PostBackOptions.... Try this instead:
<PostBackOptions
EnableReloadingUnselectedTab="true"
EnableAjax="true" EnableLoadOnDemand="false" />
<asp:ScriptManager ID="ScriptManager1" runat="server"> </asp:ScriptManager> <asp:UpdatePanel ID="UpdatePanel1" runat="server"> <ContentTemplate> <asp:Label ID="Label1" runat="server" Text="Label"></asp:Label> <ig:WebTab ID="WebTab1" runat="server" Height="184px" Width="700px" StyleSetName="Default" EnableOverlappingTabs="true"> <Tabs> <ig:ContentTabItem runat="server" Text="tab 1"> </ig:ContentTabItem> <ig:ContentTabItem runat="server" Text="tab 2"> </ig:ContentTabItem> <ig:ContentTabItem runat="server" Text="tab 3"> </ig:ContentTabItem> </Tabs> <PostBackOptions EnableAjax="true" EnableLoadOnDemand="true" /> </ig:WebTab> </ContentTemplate> </asp:UpdatePanel>
Protected Sub WebTab1_SelectedIndexChanged(ByVal sender As Object, ByVal e As Infragistics.Web.UI.LayoutControls.TabSelectedIndexChangedEventArgs) Handles WebTab1.SelectedIndexChanged Label1.Text = Now.ToLongTimeString End Sub
The SelectedIndexChanged event only first for the first click on each tab, have tried a number of combinations with PostBackOptions with no luck.
Can you show us a snippet of your code so we can help you better?
Already have the webtab control in an update panel. Trying to get it to fire on every tab change, not just the first click.
Actually, I have found out a simpler workaround... Just add a UpdatePanel around the WebTab control... Once you do that then the event will be fired for the first tab click.
Cheers,
Wagner Danda da Silva
