630
WebDatePicker does not use the width attribute
I have a <div> container set up as follows:
div class="Logs_Filter_Date_Container" style="width: 15%;">
<div class="Logs_Filter_Date_Text" style="width: 40%;">
<span><asp:Literal ID="lblStartDate" runat="server"></asp:Literal></span></div>
<div class="Logs_Filter_Date_Combo_Container" style="width: 58%;">
<ig:WebDatePicker ID="clndrStartDate" DropDownCalendarID="StartDate_WebMonthCalendar"
runat="server" Width="100%"><ClientSideEvents KeyDown="NotificationLog_calendarKeyDown" TextChanged="NotificationLog_filterChanged" />
</ig:WebDatePicker>
<ig:WebMonthCalendar ID="StartDate_WebMonthCalendar" runat="server"></ig:WebMonthCalendar></div></div>
Note the width setting on the clndrStartDate = 100%. I would expect that the control would 100% of its containing <div> which was set to 58%. However upon inspecting the control using both firebug for firefox and developertools for IE, the <table> that contains the WebDatePicker is set to 100px via an inline setting. To work around this problem I used the Logs_Filter_Date_Container CSS class to get to the table (which is essentially the WebDatePicker) and override  its width as 100%:
.Logs_Filter_Date_Combo_Container
> table
width:100% !important;
My question is why the  width attribute of the WebDatePicker is ignored and set to 100px inline?
