It is required toı change default UltraWebGrid action response against ENTER key.
Normally after writing something in a cell and pressing ENTER , the selected cell will be changed to the right cell of it. I want ENTER key to select the cell immediately below that and TAB key to select the one immediately the right and BACKSPACE immediately the left of it.
I try to control it through keydown, keyup and afterexitedit , manage to change the behaviour in IE but not FIREFOX.
What event combinations and correct orders should be used to perform that change OR
is there any other way - such as configuration option or the grid component etc - to make it possible more easily???
Hello sorry for late answer, I will check it. Thanks..
I am following up with you and if your issue was resolved.
Magued
Please refer to the following knowledge base article:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=10016
You can use similar configuration for the enter key.
