120
Composite ProbabilityChart
I am working on composite probability chart and for some reason the y-axis is Gaussian scale is lost when rendered. I am doing composite so I can control the label icons, legend and color used. below is the code.
            DeploymentScenario.FilePath = "ChartImages";
            UpperControlLimit = upperControlLimit;
            CenterLine = centerLine;
            //SetDefaultProperties();
            SetChartSize(chartSize);
            Tooltips.Display = TooltipDisplay.Never;
            /// Chart Type
            ChartType = ChartType.Composite;
            Legend.Visible = true;
            Legend.Location = LegendLocation.Left;
            /// Define Chart Area
            var chartArea = GetChartArea();
            chartArea.Bounds = new Rectangle(0, 5, 100, 100);
            CompositeChart.ChartAreas.Add(chartArea);
            /// Define common yAxis
            var yAxis = new AxisItem();
            yAxis.LineThickness = 1;
            yAxis.Margin.Far = new AxisMargin { Value = 2 };
            yAxis.Margin.Near = new AxisMargin { Value = 2 };
            yAxis.Labels.Font = new Font("Arial", 7);
            yAxis.Labels.FontColor = Color.DimGray;
            yAxis.Labels.Visible = true;
            yAxis.MinorGridLines.Visible = true;
            yAxis.Extent = 40;
            yAxis.Labels.ItemFormatString = "<DATA_VALUE:0.00>";
            /// y-axes
            yAxis.TickmarkStyle = AxisTickStyle.Smart;
            yAxis.axisNumber = AxisNumber.Y_Axis;
            yAxis.DataType = AxisDataType.Numeric;
            yAxis.SetLabelAxisType = SetLabelAxisType.GroupBySeries;
            chartArea.Axes.Add(yAxis);
            /// Define common xAxis
            var xAxis = new AxisItem();
            xAxis.Labels.FontColor = Color.DimGray;
            xAxis.Labels.Font = new Font("arial", 7);
            xAxis.Labels.Visible = true;
            xAxis.LineThickness = 1;
            xAxis.Margin.Far = new AxisMargin { Value = 2 };
            xAxis.Margin.Near = new AxisMargin { Value = 2 };
            xAxis.DataType = AxisDataType.Numeric;
            xAxis.SetLabelAxisType = SetLabelAxisType.ContinuousData;
            xAxis.Labels.ItemFormat = AxisItemLabelFormat.DataValue;
            xAxis.Labels.ItemFormatString = "<DATA_VALUE:0.00>";
            xAxis.Extent = 100;
            chartArea.Axes.Add(xAxis);
            var seriesNames = (cumProbPlotDataList.OrderBy(record => record.Name).Select(record => record.Name)).Distinct();
            var seriesIndex = 0;
            foreach (var seriesName in seriesNames)
                var paintElement = new PaintElement(CustomColorMultiseries[seriesIndex]) { FillOpacity = 150 };
                var cumProbPlotDataSeries = cumProbPlotDataList.Where(record => record.Name == seriesName);
                XYSeries xySeries = new XYSeries();
                xySeries.PEs.Add(paintElement);
                xySeries.Label = seriesName; /// if you forget this, label will not show up, ouch
                foreach (var cumProbPlotData in cumProbPlotDataSeries)
                    var xyDataPoint = new XYDataPoint(cumProbPlotData.DataPoint, (Double)cumProbPlotData.Percentile, seriesName, false);
                    xySeries.Points.Add(xyDataPoint);
                var chartLayerAppearance = new ChartLayerAppearance();
                chartLayerAppearance.ChartType = ChartType.ProbabilityChart;
                chartLayerAppearance.ChartArea = chartArea;
                chartLayerAppearance.AxisX = xAxis;
                chartLayerAppearance.AxisY = yAxis;
                chartLayerAppearance.Series.Add(xySeries);
                var probabilityChartAppearance = new ProbabilityChartAppearance();
                probabilityChartAppearance.Icon = CustomSymbolIconMultiseries[seriesIndex];
                probabilityChartAppearance.IconSize = SymbolIconSize.Medium;
                probabilityChartAppearance.LineAppearance.Thickness = 1;
                probabilityChartAppearance.LineAppearance.DrawStyle = LineDrawStyle.Dash;
                probabilityChartAppearance.ConnectWithLines = true;
                chartLayerAppearance.ChartTypeAppearances.Add(probabilityChartAppearance);
                CompositeChart.ChartLayers.Add(chartLayerAppearance);
                /// index the series
                seriesIndex++;
            /// Add composite legend
            var compositeLegend = GetCompositeLegend();
            CompositeChart.Legends.Add(compositeLegend);
            /// update the legend icon so they march the line icon
            FillSceneGraph += UpdateLabelIconFillSceneGraph;
            FillSceneGraph += CumProbPlotFillSceneGraph;
Regards and Thanks,
James
