How can I accomplish this. I get an error saying code blocks are not allowed.
Please let me know if you have any other questions about this issue.
Valerie
This is not supported, node bindings should be mapped to a single field in your data source.
There are a few options to implement such behavior:
- define node template where you can use such expressions.
- modify your data source so the TextField data is contained in a single field/property
- handle the NodeDataBound server-side event and set the node text value programatically
Hope that helps!
