how did i set a column invisible? the data (when i later select some row) i still need.in the old ultragrid i did it with
Band.Columns(0).Hidden =
True
The problem is solved when you remove the Runat="server" from the html head tag.
Same here! Having the "Hidden" attribute on ig:BoundDataField results in the error:
"The Controls collection cannot be modified because the control contains code blocks (i.e.: <% ... %>)."
No where in my entire Grid markup do I have code blocks. This occurs if I have the Hidden attribute on the BoundDataField AT ALL, regardless of the value given (true/false).
I'm working with NetAdvantage ASP.NET release 2011.1. Why? Because I have to.
i have the same error in WebDataGrid when i hide a column like this:
ig:BoundDataField DataFieldName="AufLiefPosId" DataType="System.Int32" Hidden="true" Key="PosId" Width="50px">
I use Version=11.1.20111.2020 / .net 4
Please fix this bug.
Now i use the CssClass="hidden" like above and it works fine....
Hello Martin,
I have built small sample based on provided details by you. I am not able to replicate the described issue. Could you have a look at it please? You can download it from the current post.
In the sample I am using your code as much as possible.
aspx markup :
<asp:UpdatePanel ID="UpdatePanel1" runat="server"> <ContentTemplate> <ig:WebDataGrid ID="WebDataGrid1"
runat="server"
Height="350px"
Width="98%"
AutoGenerateColumns="false"> <Behaviors> <ig:Selection RowSelectType="Multiple"
CellClickAction="Row" Enabled="true" /> <ig:RowSelectors RowNumbering="true"
Enabled="true" /> </Behaviors> </ig:WebDataGrid> </ContentTemplate> </asp:UpdatePanel>
Code file:
if (!Page.IsPostBack) { //Add behavior this.WebDataGrid1.Behaviors.CreateBehavior<Paging>(); //Handle PageIndexChanged event this.WebDataGrid1.Behaviors.Paging.PagingClientEvents .PageIndexChanged = "WebDataGrid1_PageIndexChanged"; BoundDataField Datacolumn1 = new BoundDataField(); Datacolumn1.DataFieldName = "id"; Datacolumn1.Key = "id"; Datacolumn1.Header.Text = "id"; Datacolumn1.Hidden = true; WebDataGrid1.Columns.Add(Datacolumn1); Datacolumn1 = new BoundDataField(); Datacolumn1.DataFieldName = "Item"; Datacolumn1.Key = "Item"; Datacolumn1.Header.Text = "Item"; Datacolumn1.Hidden = false; WebDataGrid1.Columns.Add(Datacolumn1); Datacolumn1 = new BoundDataField(); Datacolumn1.DataFieldName = "Data"; Datacolumn1.Key = "Data"; Datacolumn1.Header.Text = "Data"; Datacolumn1.Hidden = false; WebDataGrid1.Columns.Add(Datacolumn1); } WebDataGrid1.DataSource = this.MakeTable(); WebDataGrid1.DataBind(); this.WebDataGrid1.Behaviors.Paging.PagerTemplate = new CustomPagerTemplate();
As you can see I hide the first column as you suggested.
Let me know what I am missing in this sample to get the error.
Hi Lyuba, (juhu it works)if i writeDatacolumn1.Header.CssClass = "hidden"Datacolumn1.CssClass ="hidden"is important because of the header will display but not the column. if i write both , both is hidden, the complete column is hidden:)many thanks for the help>if it is possible for you to attach a sample in the support ticket that you created it would be very nice i think if you simple write .hidden=false everyone can reproduce the error. hope you can fix itthanks martin
