Hi Team,
While sorting in the grid a runtime script error is occuring as follows.
How can i overcome it?
Expecting your reply in this in soon.
Thanks & Regards,
Assyst
Hi Dave,
The service release RTM build (2158) of 10.2 done the thing. In this release the issue was resolved. Thanks for your support.
Hello Assyst,
You can view all of your available downloads under the “My IG” tab on the Infragistics.com website.
Here is a direct link:
https://ko.infragistics.com/Login.aspx?ReturnUrl=%2fMembership%2fDefault.aspx%3fpanel%3dDownloads&panel=Downloads
If you have difficulty logging in, or do not see your product, please let me know.
I am available if you need further assistance.
Thank you,
Stephani
DSManager@infragistics.com
Dave,
The file i had attached shows out the error. Just download and run the same with the dll's with the attachment. The error will pop out. I am sure because I had reproduced the error in this attachment. And by the way how can I update to the latest service release and let me check with the update and I will verify with it. Please provide me the steps to upgrade to the latest service release.
Assyst,
I downloaded the sample and ran it with the latest internal code for 10.2. I could not reproduce your error. I did notice that you were running the RTM build (1011) of 10.2. If you upgrade to the latest Service Release, this issue should go away.
regards,
Dave
I have attached a small sample with a button to implement AjaxPro method. Hopes now you can help me in this problem as soon as possible. Hopes for the solution in soon and thanks in advance.
Please do find the attached sample (zipped one).
