I have a webdatagrid having 6 columns.
Out of 6 columns, 4 columns are webdropdown.
when i try clicking to add row, it seems to be disabled.
Only column which are not webdropdown are active.
How to solve this issue...
I did the same way you mentioned, but it's not working.
Moreover If i try to update any cell of a particular row, the grid becomes unresponsive for a long time(about 2 minute). Delete is not working.
All the CRUD operation work fine if we don't have dropdowns in grid.
What is the solution for this???
It sounds like you were setting the drop downs as editor providers for cell editing? So you had column settings for that behavior. You would need to do the same thing for the add row. Have column settings where you supply the column key and editor ID. I hope this is what you want.
-Dave
I have used EditorControl.
All dropdown columns are bounded to datasource.
But in new row , drop down doesn't appear
Are the columns with drop downs templated columns? Those columns are not bound to any data, so they do not enter edit mode in the add row.
regards,
David Young
