Hi Mike,
Kindly Provide the soln of the problem explained in the attached doc file.
Its urgent.
Following is the code for report printing.
protected void UltraWebGridDocumentExporter1_BeginExport(object sender, DocumentExportEventArgs e) { // Add a title to the report ReportText.IText heading = e.Section.AddText(); ReportText.Style headingStyle = new ReportText.Style(new Infragistics.Documents.Graphics.Font("Tahoma", 16), Infragistics.Documents.Graphics.Brushes.Crimson); heading.AddContent("Activity For Specified Period ", headingStyle); heading.AddLineBreak(); heading.Alignment = Infragistics.Documents.Report.TextAlignment.Center; heading.AddContent("Printed By: Optimal Infotech Pvt Ltd ", headingStyle); heading.AddLineBreak(); heading.Margins.Bottom = 15; // Add a caption with some more information ReportText.IText caption = e.Section.AddText(); ReportText.Style captionStyle = new ReportText.Style(new Infragistics.Documents.Graphics.Font("Tahoma", 12), Infragistics.Documents.Graphics.Brushes.Black); caption.AddContent("Buyer:", captionStyle); caption.AddLineBreak(); caption.AddContent("Merchandiser:", captionStyle); caption.AddLineBreak(); caption.AddContent("User:", captionStyle); caption.AddLineBreak(); caption.AddContent("From Date:", captionStyle); caption.AddLineBreak(); caption.AddContent("To Date:", captionStyle); caption.AddLineBreak(); caption.Margins.Bottom = 15; // Get a reference to the section's PageNumbering object. Infragistics.Documents.Report.Section.PageNumbering pn = e.Section.PageNumbering; //Add a Footer to the report e.Section.PageMargins.All = 40; // Create a style for the page numbering font. pn.Style = new Infragistics.Documents.Report.Text.Style(Fonts.Arial, Infragistics.Documents.Graphics.Brushes.Black); // The Template property is the actual string that shows the page numbering. Use the [Page #] place- // holder for the current page and the [TotalPages] place-holder for the total amount of pages in the entire document. pn.Template = "Page [Page #] of [TotalPages]"; // The page numbering will be aligned with the right side of the page. Valid values off the // Alignment enum include Left, Center, and Right. pn.Alignment.Horizontal = Infragistics.Documents.Report.Alignment.Right; // The page numbering will be located at the bottom of the page. Valid values off the Alignment enum include Top and Bottom. pn.Alignment.Vertical = Infragistics.Documents.Report.Alignment.Bottom; // The page numbering is at the extreme bottom of the page, so we need to change the Y Offset in order to bring it in line with the rest of // the page footer text. pn.OffsetY = -18; Infragistics.Documents.Report.Section.ISectionFooter footer = e.Section.AddFooter(); footer.Height = 30; ReportText.IText text = footer.AddText(0, -18); text.AddContent(string.Format("Date printed: {0}", DateTime.Now.ToString("dd-MM-yyyy"))); // customize the grid for export //UltraWebGrid1.Columns.FromKey("CustomerID").Hidden = true; }
protected void btnexportpdf_Click(object sender, ImageClickEventArgs e) { try { //// configure exporter UltraWebGridDocumentExporter1.Format = FileFormat.PDF; UltraWebGridDocumentExporter1.DownloadName = "ActSpecifiedPeriod.pdf"; UltraWebGridDocumentExporter1.TargetPaperOrientation = PageOrientation.Landscape; UltraWebGridDocumentExporter1.ExportMode = Infragistics.WebUI.UltraWebGrid.Exporter.ExportMode.Download; UltraWebGridDocumentExporter1.AutoSizeRows = Infragistics.WebUI.Shared.DefaultableBoolean.True; // trigger export UltraWebGridDocumentExporter1.Export(grdActSpecifiedgrid); } catch (Exception ex) { Response.Write(ex.Message); } }
