We have an application that use the WebHtmlEditor. It is working fine except on iPhone/Ipad's Safari. The component is locked.
We are in version 2010.1.
Do you have any update on whether this feature is being considered? I am using v10.3 of the NetAdvantage suite and am having the same issue on the iPhone and iPad. We would like to declare our ASP.Net application fully iPad supported and this limitation of the WebHTMLEditor is holding that up. Any update on this feature request would be appreciated.
Phil Peters
Visual Lease - Lead Developer
Hello Caron,
This is just a follow up on any further questions you have in regards to the feature request submitted. If not then case will be closed. You also have the option to reopen later as well.
Thank you for contacting Developer Support.
Sincerely,Duane HoytDeveloper Support Engineer, MCTSInfragisticshttp://ko.infragistics.com/support
