I'm using the WebDataTree and having a problem with the way it is initially rendering. What happens after a pageload and the end user gets the response, the main wrapper/div of the control, has a default style that includes visibility=visible.. I cannot have this since it will be hidden on page load (Even if the tree control is inside a hidden div, it will still be visible)
I have not found an easy way where I can take of that visibility=visible.. I don't see it in the defaultstyles css files, and when I say webdatatree.style["visibility"] = ""; or webdatatree.style["visibility"] = "hidden"; it still returns visibility=true..
Is there a way I can solve this without useing the sourcecode or doing something onPreRender ?
Please help
Neat, I tried what you said above and it works. Below is an example for anyone who happens to come across this.. The only thing is that if I want it hidden by default on initial load, it will flash visible on the client browser and then it will invoke the ClientInit function i have below. If you don't want the flash you will probably have to alter the resource file.. This will do, thanks!
MARKUP:<ig:WebDataTree ID="tvMSelect" runat="server" CheckBoxMode="TriState" ClientEvents-Initialize="TreeVisibility"></ig:WebDataTree>
CODE - BEHIND:StringBuilder sb = new StringBuilder(); sb.AppendLine();sb.AppendLine(@"function TreeVisibility(sender)");sb.AppendLine(@"{");sb.AppendLine(@" sender.get_element().style.visibility = """";");sb.AppendLine(@"}");if (ScriptManager.GetCurrent(this.ContainerPage).IsInAsyncPostBack){ ScriptManager.RegisterClientScriptBlock(this.ContainerPage, typeof(string), "TreeVisibility", sb.ToString(), true); }else { this.ContainerPage.ClientScript.RegisterClientScriptBlock(typeof(string), "TreeVisibility", sb.ToString(), true); }
Hey Lubomir,
Thanks for the response. This option looks very good and the way to go.. Unfortunatly, I spent the time yesterday and updated the resource file so it just says style.visibility = ""..
There are so many properties/functions that it is easy to overlook.
Anyways, I will try your answer.. I'm sure it'll do the job.
Thank you
you can attach to the client side Initialize event. Then you can use the sender which represents the WebDataTree control object and say: sender.get_element().style.visibility = "";
sender.get_element() will return the main DIV element of the control.
Hope this helps.
Lubomir
im still unable to find a way... I tried working with the Render event and noticed after a while that there is a javascript function inside a resource file called by the client somewhere on clientside pageload or something...
///<summary>
/// The WebDataTree class is used to represent the object model of a the WebDataTree ASP.Net Server control.
///</summary>
$IG.WebDataTree =
function(element){$IG.WebDataTree.initializeBase(this, [element]);element.style.visibility = "visible";this._bindings = this._getPropertyBindings();
why????????? how can this be stopped
