315
Missing something simple...WHDG Data Update
Hi, I am just starting to use the WHDG as a evaluation measure. I got stuck with something basic. I am using the start-up solution and trying to save the data back to the Access database using the following code on RowUpdating event.
Oddly enough, after I update the data on the grid and on existing the row when I check the data in the debugger at runtime, I see the rec.Items[...].value shows the original values retrieved from the database but does not show any of the updated data I changed in UI. Can someone suggest what am I missing here?
protected void WebHierarchicalDataGrid1_RowUpdating(object sender, Infragistics.Web.UI.GridControls.RowUpdatingEventArgs e)
        Infragistics.Web.UI.GridControls.GridRecord rec = e.Row;
        ContainerGrid grid = (ContainerGrid) sender;
        grid.DataKeyFields = "CategoryID";
        DataSet ds = new DataSet();
        OleDbConnection conn = new OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\\Users\\Public\\Documents\\Infragistics\\NetAdvantage 2010.2\\ASP.NET\\Startup Solution\\App_Data\\Nwind.mdb");
        conn.Open();
        OleDbDataAdapter adp = new OleDbDataAdapter();
        adp.UpdateCommand = conn.CreateCommand();
        string sql = "UPDATE [Categories] SET [CategoryName] = '" + rec.Items[1].Value + "', [Description] = '" + rec.Items[2].Value + "' WHERE [CategoryID] = " + Int32.Parse(rec.Items[0].Value.ToString());
        adp.UpdateCommand.CommandText = sql;
        adp.UpdateCommand.ExecuteNonQuery();
        conn.Close();
        grid.DataSource = ds;
        grid.DataBind();
  • 315
    Verified Answer
    I got it now...
    Instead of using rec.Items[0].Value, I had to use the e.Values[<boundcolumnname>].ToString() to retrieve the updated data value. Now I could use the updated values to update the database using the UpdateCommand object.
