I installed your product on my PC to make several changes to an existing ASP.NET application. We are replacing several AJAX Controls from the open source toolkit with the Infragistics NetAdvantage 2010.2 ASP.NET toolkit.
The installation of Infragistics NETAdvantage 10.2 was successful. I then open an existing ASP.NET project in VS2008. I add a reference for Infragistics Web 3.5 v10.2 to the project (and it shows under "References") and I add the Infragistics namespace to the ASP.NET source. However the controls are not showing in the Visual Studio 2008 toolbox window for the designer with the other controls. I must be missing a step.
Please help.
At first, that option did not run - return a file-not-found error in the midst of the process. I re-ran it with RUN-AS Administrator and it ran OK.
Thank you.
Use the toolbox utility to add the items to the toolbox. You can find it in your start menu under:
Programs\Infragistics\NetAdvantage 2010.2\ASP.NET\Utilities\Create Toolbox Tab for CLR 3.5
