I am having a strange problem with the WHDG control. I see vertical scrollbar on the browser with increase in the number of rows in the WHDG. The WHDG has height set to 350px. When the rows increase, there should be vertical scrollbar on the WHDG. In addition to the WHDG vertical scrollbar, the browser also has its own. My WHDG has 2 level hierarchy. I am failing to figure out the issue.
I appreciate the help!!
Has any advice been given on this? I am currently upgrading from the ultrawebgrid and am experiencing the same problem. The ultrawebgrid did not create a scrollbar when expanding child rows, is there a way to stop the scrollbar appearing in the webhierarchicaldatagrid.
Luke
Attached is the image that shows the browser vertical srollbar by dropping WHDG on an ASPX page
Hi Lyuba,
Could you please guide us with this issue? I have dropped a WHDG on an ASPX page that displays 2 levels of data. With increase in the number of rows in the WHDG, the browser vertical scroll bar is displayed and it also increases. Is there any workaround for this issue or do I have to open a case with Infragistics support for the resolution? I would appreciate your response!
