i have UltraWebGrid Ver(8.1.20081.1000). Code Behind vb.net
I created the columns in server side including one check box column.
If select check box column i can able to get the check box column value in client side,
But i can't able to get the check box column value in in server side.
'*** Client Side i am using this Code
function grdLvAprRej_AfterCellUpdateHandler(gridName, cellId)
var myGrid = igtbl_getGridById(gridName);
var cell = igtbl_getCellById(cellId);
var check = cell.getValue();
alert(check);
'*** Server Side i am using this code
for i = 0 to myGrid.rows.count
check = myGrid.Rows(0).Cells.FromKey("SelectC").Value
msgbox (check)
next
How can i get the check box column value in server side.
Please help me to do this.
I also have same problem, used your check box code in server side it is working in all browsers but in ie11 without compatibility it is not working.
isn't the checkbox supposed to be a boolean?
so are u looking for true or false to return? here is what i got:
c#:
string result;
foreach(UltraGridRow dRow in myGrid.Rows)
bool check = Convert.ToBoolean(dRow.Cells.FromKey("SelectC").Value);
result = check.ToString();
OR IN VB.NET:
For Each dRow As UltraGridRow In myGrid.Rows
Dim check As Boolean = Convert.ToBoolean(dRow.Cells.FromKey("SelectC").Value)
Next
