Who set the widht and heigt automatic?
Please feel free to contact me if you have any further questions regarding this matter.
Hello Babar,
If your question in this case is displaying multiple series in a single WebChart, a Composite chart may allow you to fulfill your requirements:
https://ko.infragistics.com/samples/aspnet/chart/composite-chart-layers
Any additional information regarding the scenario in this case would allow me to provide you with more feedback.
Do not hesitate to contact me with any updates or additional questions.
i have two series:
Series1 and Series2
Series1 with 2 pint and Series2 with 5 point passing this series chart show only to point of both Series
i showing all points of all Series
thanks
How can I change the size of de UltraChart in the codebehind file?
When I set the size in the ASCX markup page, then the given size is used for the chart, but when I set the size from codebehind, then de chart uses its default size (400x300). Why is this?
Is this a bug? And how can I change the size from codebehind???
Klaas Polinder
Where do you set the DataSource of the chart instance? Can you give some code and/or a screen shot of the result, so I could see what is going on and advise you further.
