I am frustrated with figuring out how to set up the report which have 1 or more gridview to be printout, but need to be printout in the right place.
Plus when I like to see header change after different type of report come in.
For example
Log of checks received:
ACCT DBA/EMPLOYER NAME Check Amout Check Date
1233 ABC12 25.00 9/20/2010
1235 DCE 15.00 8/20/2010
page 1
MultiCheck breakdown
12389 ABCDF12 125.00 9/20/2010
12359 adcDCE 115.00 8/20/2010
page 2
Is that possible
My code is here
Dim otable, otable2 As Data.DataTable Dim vstr As String Dim a1 As New ArrayList Dim aTots(8) As Double Dim myDocuments As String = "H:\" Dim myDocuments2 As String = HttpContext.Current.Request.PhysicalApplicationPath Dim headerstyle As New Infragistics.Documents.Report.Text.Style(New Font("Arial", 14, FontStyle.Bold), Brushes.Black) Dim textStyle As New Infragistics.Documents.Report.Text.Style(New Font("Arial", 8, FontStyle.Regular), Brushes.Black) Dim headerSmall As New Infragistics.Documents.Report.Text.Style(New Font("Arial", 10, FontStyle.Regular), Brushes.MediumBlue) Dim headerTiny As New Infragistics.Documents.Report.Text.Style(New Font("Arial", 8, FontStyle.Regular), Brushes.Black) Dim headerBlank As New Infragistics.Documents.Report.Text.Style(New Font("Arial", 4, FontStyle.Regular), Brushes.White) Dim gridstyle As New Infragistics.Documents.Report.Text.Style(New Font("Arial", 10, FontStyle.Bold), Brushes.Black) Dim theReport As New Infragistics.Documents.Report.Report() Dim strCT, strCT1 As String Dim theSection As Infragistics.Documents.Report.Section.ISection = theReport.AddSection() 'Table Pattern (think of this as a kind of "Style Sheet" for ITable theSection.PageOrientation = Infragistics.Documents.Report.PageOrientation.Landscape
theReport.Preferences.Printing.PaperSize = Infragistics.Documents.Report.Preferences.Printing.PaperSize.Auto theReport.Preferences.Printing.PaperOrientation = Infragistics.Documents.Report.Preferences.Printing.PaperOrientation.Auto theReport.Preferences.Printing.FitToMargins = True Dim pn As Infragistics.Documents.Report.Section.PageNumbering = theSection.PageNumbering ' Create a style for the page numbering font. pn.Style = headerTiny
' The Template property is the actual string that ' shows the page numbering. Use the [Page #] place- ' holder for the current page and the [TotalPages] ' place-holder for the total amount of pages in ' the entire document. pn.Template = "Page [Page #] of [TotalPages]"
' Setting SkipFirst to true does not place page ' numbering on the first page of the section. This ' is useful if the first page is a Title page. pn.SkipFirst = False
' The page numbering will be aligned with the ' right side of the page. Valid values off the ' Alignment enum include Left, Center, and Right. ' pn.Alignment.Horizontal = Infragistics.Documents.Report.Alignment.Right
' The page numbering will be located at the ' bottom of the page. Valid values off the ' Alignment enum include Top and Bottom. ' pn.Alignment.Vertical = Infragistics.Documents.Report.Alignment.Bottom
' The page numbering is at the extreme bottom ' of the page, so we need to change the Y Offset ' in order to bring it in line with the rest of ' the page footer text. pn.OffsetY = -5
Dim theTablePattern As New Infragistics.Documents.Report.Table.TablePattern() theTablePattern.Header.Repeat = True
Dim theTablePattern1 As New Infragistics.Documents.Report.Table.TablePattern() theTablePattern1.Header.Repeat = True
theTablePattern.Header.Cell.Background = New Infragistics.Documents.Report.Background(Infragistics.Documents.Graphics.Brushes.LightGray) theTablePattern.Row.Cell.Background = New Infragistics.Documents.Report.Background(Infragistics.Documents.Graphics.Brushes.White) 'for 2nd one theTablePattern1.Header.Cell.Background = New Infragistics.Documents.Report.Background(Infragistics.Documents.Graphics.Brushes.LightGray) theTablePattern1.Row.Cell.Background = New Infragistics.Documents.Report.Background(Infragistics.Documents.Graphics.Brushes.White)
Dim tableCellPattern As New Infragistics.Documents.Report.Table.TableCellPattern() Dim tableCellPattern1 As New Infragistics.Documents.Report.Table.TableCellPattern() Dim theTable As Infragistics.Documents.Report.Table.ITable = theSection.AddTable() Dim theTable2 As Infragistics.Documents.Report.Table.ITable = theSection.AddTable() theSection.PageMargins = New Infragistics.Documents.Report.Margins(15.0F) theTable.ApplyPattern(theTablePattern) theTable2.ApplyPattern(theTablePattern1)
Dim theHeaderCell As Infragistics.Documents.Report.Table.ITableCell = Nothing
Dim theHeaderText As Infragistics.Documents.Report.Text.IText = Nothing Dim theHeaderCell1 As Infragistics.Documents.Report.Table.ITableCell = Nothing
Dim theHeaderText1 As Infragistics.Documents.Report.Text.IText = Nothing 'Iterate through the Grid Cols and create corresponding headers in the ITable
'creates a non repeating header Dim sect1Head As Infragistics.Documents.Report.Section.ISectionHeader = theSection.AddHeader() sect1Head.Repeat = True sect1Head.Height = 20 'styles used in the header
'adds a group to the header to help layout contents 'Dim footer As Infragistics.Documents.Report.Section.ISectionFooter = theSection.AddFooter() 'footer.Height = -3 'Dim text As Infragistics.Documents.Report.Text.IText = footer.AddText(0, -10) 'text.AddContent(String.Format("Print {0}", DateTime.Now.ToString("MM/dd/yyyy hh:mm")), headerTiny) 'footer.Repeat = True Dim sect1HeadGroup As Infragistics.Documents.Report.IGroup = sect1Head.AddGroup(0, 0) 'using grid to layout first set of elements Dim sect1HeadGroupGrid As Infragistics.Documents.Report.Grid.IGrid = sect1HeadGroup.AddGrid() 'using the gridpattern to style the grid 'Dim gridPattern As New Infragistics.Documents.Report.Grid.GridPattern() 'gridPattern.Margins = New Infragistics.Documents.Report.Margins(5) 'gridPattern.Paddings = New Infragistics.Documents.Report.Paddings(10) 'sect1HeadGroupGrid.ApplyPattern(gridPattern) 'adds 5 columns, columns must be added for a grid element sect1HeadGroupGrid.AddColumn() sect1HeadGroupGrid.AddColumn() 'frist row of the grid in the header Dim headergridrow1 As Infragistics.Documents.Report.Grid.IGridRow = sect1HeadGroupGrid.AddRow() Dim r1c2 As Infragistics.Documents.Report.Grid.IGridCell = headergridrow1.AddCell() 'Dim rlc3 As Infragistics.Documents.Report.Grid.IGridCell = headergridrow1.AddCell Dim sect1HeadText As Infragistics.Documents.Report.Text.IText = r1c2.AddText()
vstr = "SELECT * FROM OPENQUERY(CONTRIBORACLE,'Select ACCT, RECD, APPLIED, CREDIT, CKDATE, NAME1, tcode(''D'' || Disp) D, DISP, ReceiptNum, CLERK, REFER, SPECIAL, COMMENTS, WORKER, BATCH from TAXDEV.chklog where " vstr = vstr & " UNIT =''" & Me.SessionState("Unit") & "'' AND (Recd = ''" & PageFuncts.SQLDtoC(Me.SessionState("aDate")) & "'' " vstr = vstr & "or applied = ''" & PageFuncts.SQLDtoC(Me.SessionState("aDate")) & "'') AND (DISP = ''1'' OR DISP = ''3'') " vstr = vstr & "order by DISP, " & SortRB.SelectedValue & " ')" otable = PageFuncts.SqlSelect(vstr, strCntrbDbConn) ulwbgvdCHKLOGRECV.DataSource = otable ulwbgvdCHKLOGRECV.DataBind()
If ulwbgvdCHKLOGRECV.Rows.Count > 0 Then Dim theGrid As Infragistics.WebUI.UltraWebGrid.UltraWebGrid theGrid = ulwbgvdCHKLOGRECV
'sect1HeadText.Alignment = Infragistics.Documents.Report.TextAlignment.Left Dim strHeader As String = "Log of checks received:" + Me.SessionState("aDate") + "-" + Me.SessionState("cUnit") sect1HeadText.AddContent(strHeader, headerstyle) 'adds a rule after the grid 'adds a rule after the grid Dim rule2 As Infragistics.Documents.Report.IRule = sect1HeadGroup.AddRule rule2 = sect1HeadGroup.AddRule() rule2.Pen = New Pen(New Color(255, 255, 255)) rule2.Pen.Width = 1 rule2.Pen.Style = DashStyle.Solid sect1HeadGroup.AddRule()
For Each c As Infragistics.WebUI.UltraWebGrid.UltraGridColumn In theGrid.Columns
theHeaderCell = theTable.Header.AddCell() theHeaderText = theHeaderCell.AddText()
theHeaderText.Style.Font = New Infragistics.Documents.Graphics.Font("Arial", 8) theHeaderText.Style.Font.Style = FontStyle.Bold ' theHeaderText.Style.Brush = New Infragistics.Documents.Graphics.SolidColorBrush(Infragistics.Documents.Graphics.Colors.WhiteSmoke)
theHeaderText.AddContent(c.Header.Caption) Next
Dim theRow As Infragistics.Documents.Report.Table.ITableRow = Nothing Dim theRowCell As Infragistics.Documents.Report.Table.ITableCell = Nothing
Dim theRowText As Infragistics.Documents.Report.Text.IText = Nothing 'Now create your rows:
For Each r As Infragistics.WebUI.UltraWebGrid.UltraGridRow In theGrid.Rows If theGrid.Rows.Count = 0 Then
ElseIf theGrid.Rows.Count > 0 Then theRow = theTable.AddRow()
For Each c As Infragistics.WebUI.UltraWebGrid.UltraGridColumn In Me.ulwbgvdCHKLOGRECV.Columns
theRowCell = theRow.AddCell() ' theRowCell.Width = New Infragistics.Documents.Report.RelativeWidth(220) tableCellPattern.Apply(theRowCell) theRowText = theRowCell.AddText()
theRowText.Style.Brush = New Infragistics.Documents.Graphics.SolidColorBrush(Infragistics.Documents.Graphics.Colors.Black) theRowText.Style.Font = New Infragistics.Documents.Graphics.Font("Arial", 8) Dim strString, strKey As String Dim strDate As Date
strKey = r.Cells.FromKey(c.Key).Key.ToString
If strKey = "CK_DATE" Then strString = r.Cells.FromKey(c.Key).Value.ToString() strDate = strString strString = strDate Else If (r.Cells.FromKey(c.Key).Value) = Nothing Then strString = "" Else strString = r.Cells.FromKey(c.Key).Value.ToString() End If
End If theRowText.AddContent(strString)
Next End If
Next otable.Dispose()
End If
vstr = "SELECT * FROM OPENQUERY(CONTRIBORACLE,'Select ACCT, RECD, APPLIED, CREDIT, CKDATE, NAME1, tcode(''D'' || Disp) D, DISP, ReceiptNum, CLERK, REFER, SPECIAL, COMMENTS, WORKER, BATCH from TAXDEV.chklog where " vstr = vstr & " UNIT =''" & Me.SessionState("Unit") & "'' AND (Recd = ''" & PageFuncts.SQLDtoC(Me.SessionState("aDate")) & "'' " vstr = vstr & "or applied = ''" & PageFuncts.SQLDtoC(Me.SessionState("aDate")) & "'') AND (DISP = ''2'') " vstr = vstr & "order by DISP, " & SortRB.SelectedValue & " ')" otable = PageFuncts.SqlSelect(vstr, strCntrbDbConn) ulwbgvdCHKREF.DataSource = otable ulwbgvdCHKREF.DataBind() If ulwbgvdCHKREF.Rows.Count > 0 Then
Dim theGrid2 As Infragistics.WebUI.UltraWebGrid.UltraWebGrid theGrid2 = ulwbgvdCHKREF
For Each c1 As Infragistics.WebUI.UltraWebGrid.UltraGridColumn In theGrid2.Columns
theHeaderCell1 = theTable2.Header.AddCell() theHeaderText1 = theHeaderCell1.AddText()
theHeaderText1.Style.Font = New Infragistics.Documents.Graphics.Font("Arial", 8) theHeaderText1.Style.Font.Style = FontStyle.Bold ' theHeaderText.Style.Brush = New Infragistics.Documents.Graphics.SolidColorBrush(Infragistics.Documents.Graphics.Colors.WhiteSmoke)
theHeaderText1.AddContent(c1.Header.Caption) Next
Dim theRow1 As Infragistics.Documents.Report.Table.ITableRow = Nothing Dim theRowCell1 As Infragistics.Documents.Report.Table.ITableCell = Nothing
Dim theRowText1 As Infragistics.Documents.Report.Text.IText = Nothing 'Now create your rows:
For Each r1 As Infragistics.WebUI.UltraWebGrid.UltraGridRow In theGrid2.Rows If theGrid2.Rows.Count = 0 Then
ElseIf theGrid2.Rows.Count > 0 Then theRow1 = theTable2.AddRow()
For Each c1 As Infragistics.WebUI.UltraWebGrid.UltraGridColumn In Me.ulwbgvdCHKREF.Columns
theRowCell1 = theRow1.AddCell() ' theRowCell.Width = New Infragistics.Documents.Report.RelativeWidth(220) tableCellPattern1.Apply(theRowCell1) theRowText1 = theRowCell1.AddText()
theRowText1.Style.Brush = New Infragistics.Documents.Graphics.SolidColorBrush(Infragistics.Documents.Graphics.Colors.Black) theRowText1.Style.Font = New Infragistics.Documents.Graphics.Font("Arial", 8) Dim strString1, strKey1 As String Dim strDate1 As Date
strKey1 = r1.Cells.FromKey(c1.Key).Key.ToString
If strKey1 = "CK_DATE" Then strString1 = r1.Cells.FromKey(c1.Key).Value.ToString() strDate1 = strString1 strString1 = strDate1 Else If (r1.Cells.FromKey(c1.Key).Value) = Nothing Then strString1 = "" Else strString1 = r1.Cells.FromKey(c1.Key).Value.ToString() End If
End If theRowText1.AddContent(strString1)
Next End If Next otable.Dispose() End If
Dim strfilename, strUnitFile, f_name As String strfilename = Me.SessionState("aDate").Replace("/"c, "_"c) strUnitFile = Me.SessionState("cUnit").Replace(" "c, "_"c)
' f_name = myDocuments + "Reports\TOTAL_WORKORDER_SUBMITTED_" + strNewCalendar + ".pdf" f_name = myDocuments2 + "Reports\" + strUnitFile + "_" + strfilename + ".pdf" ' f_name = myDocuments + "TOTAL_WORKORDER_SUBMITTED_" + strfilename + ".pdf"
theReport.Preferences.Printing.PaperOrientation = Infragistics.Documents.Report.Preferences.Printing.PaperOrientation.Landscape
theReport.Publish(f_name, Infragistics.Documents.Report.FileFormat.PDF) Dim strScript As String ' ulwbgvdCHKLOGRECV.Visible = False strScript = "<script language = javascript>window.open('REPORTS/" + strUnitFile + "_" + strfilename + ".pdf')</script>" ' strScript = "<script language = javascript>window.open('file:///h:/Contributions - UI TAX/TOTAL_WORKORDER_SUBMITTED_" + strfilename + ".pdf')</script>" ClientScript.RegisterClientScriptBlock(Me.GetType(), "strScript", strScript) 'Write out to the response.Output Stream and you are done. ' ulwbgvdCHKLOGRECV.Visible = False
So far it is like this
Page 1
Hello Rob,
It's been a while since you have submitted this.
I would recommend you using UltraWebGridDocumentExporter exporter to achieve this (like Luyba has advised you regarding the Excel exporter)
http://community.infragistics.com/forums/p/44079/240675.aspx#240675
Let me know if you need further assistance
