i've licensed Infragistic 9 WebDataGrid.
Today i see an custom Paging (see screenshot below) which is created with Infragistic 2010 WebdataGrid,
Is it also possible to do this with Infragistic 9 ? Thank you for your feedback!
May somebody has also the needed Code for Infragistic 9 ?
Link to online Example with Source Code : http://samples.infragistics.com/2010.2/WebFeatureBrowser/Default.aspx
Hi newling,
You are using the UltraWebGrid and are referring to a WebDataGrid sample. These two grids have different structures. You might be able to reuse some code, but to use the sample as it is, you would need to migrate your control to the WebDataGrid.
regards,Dave
Hi David Young,
thank you for quick reply. That sounds great for me i've to test the Custom paging for my projects.
I'm using following Infragistic components :
Nothing has changed in paging since it shipped in 2008.3. When you say Infragistics 9, I assume you mean either version 9.1 or 9.2? You should be able to do that custom page in those versions. Have you tried using the code in your project? Just make sure any build numbers and version match those that you are using.
regards,David Young
