535
Run time columns not showing
Hello everyone,
I am having problems with a webdatagrid, I have created 2 bounddatafield objects which I have added to the webdatagrid.columns collection.
After that, I assigned a dataset to function as a datasource (I also turned off autogeneratecolumns)
I then called the webdatagrid.databind function to finalise the proces.
The problem is that the columns aren't being rendered on screen. When debugging I can see that the webdatagrid has 2 columns.
The purpose of this project is that I want users to be able to set the datasource through a combobox, so I want to set the datasource of the grid dynamically but I only want to show 2 or 3 column of the datatable.
Any help would be appreciated
Private Sub Page_PreRender(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.PreRender
        Dim adapt As New DSMailboxTableAdapters.t_InboxTableAdapter
        adapt.FillByMechanicID(_ds.t_Inbox, _mechanicID)
        WebDataGrid1.AutoGenerateColumns = False
        Dim c_Message As New Infragistics.Web.UI.GridControls.BoundDataField
        c_Message.DataFieldName = "Message"
        c_Message.Key = "Message"
        Dim c_Status As New Infragistics.Web.UI.GridControls.BoundDataField
        c_Status.DataFieldName = "MessageStatus"
        c_Status.Key = "MessageStatus"
        WebDataGrid1.Columns.Add(c_Message)
        WebDataGrid1.Columns.Add(c_Status)
        WebDataGrid1.DataSource = _ds.t_Inbox
        WebDataGrid1.DataBind()
    End Sub
