590
WDG - How can I tell if the column is a template field?
I am iterating through my grid as below and need to base some logic on whether the grid column in question - gridField is a template field or a bound field of the grid.
foreach (GridField gridField in wdg.Columns)
Hope someone can help.
  • 33839
    Verified Answer
    Hi asanghi,
    Could you try the following?
    bool isTemplate = gridField is TemplateDataField;
    If that doesn't quite work, you could try getting the actual type.  And then compare it to typeof(TemplateDataField).
    regards,
    David Young
