I am trying to test on IE6 which I only have available over Windows Remote Desktop. I can run on my local (XP) machine w/IE8 and ig:WebDialogWindow controls display fine. They are set Modal. I try to run the web pages from RemoteDesktop IE6 and no display. I can view page source and see the code is loaded for the dialog window but no display. Any ideas?
Thank you.
Hi Evensen,
Please let me know if you have any questions with this matter.
NehaDeveloper Support EngineerInfragisticswww.infragistics.com/support
Based on your description, I have put together a sample to reproduce the issue and when run on my machine with IE6 it works as expected.
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
If this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
