I use v10.2.20102.2101
I have a simple webpage with a : ScriptManager, UpdatePanel,WebDialogWindow,button and webCombo
When i have the combo and WebDialogWindow in the page and i run my webpage i does'nt see the page.
If i delete the WebDialogWindow my page work or if i delete the combo my page work. the both control in same page do the problem.
What is the solution?
Here is my code of webpage doesn't work with webcombo:
<%@ Page Language="vb" AutoEventWireup="false" CodeBehind="wfBug_Dialog.aspx.vb" Inherits="WebPortailCegertec.wfBug_Dialog" %><%@ Register assembly="Infragistics35.Web.v10.2, Version=10.2.20102.2101, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.LayoutControls" tagprefix="ig" %><%@ Register assembly="Infragistics35.WebUI.WebCombo.v10.2, Version=10.2.20102.2101, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.WebCombo" tagprefix="igcmbo" %><%@ Register assembly="Infragistics35.WebUI.UltraWebGrid.v10.2, Version=10.2.20102.2101, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebGrid" tagprefix="igtbl" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head id="Head1" runat="server"> <title></title> <link href="../../Styles/StyleChargement.css" rel="stylesheet" type="text/css" /> <link href="../../Styles/controle.css" rel="stylesheet" type="text/css"/></head>
<body> <form id="form1" runat="server" enableviewstate="True"> <!-- Le ScriptManager est nécéssaire pour faire fonctionner le (UpdatePanel ou WebDialogWindow) --> <asp:ScriptManager ID="scriptMgr" runat="server" /> <!-- Cette section est miss a jours sur le PostBack --> <asp:UpdatePanel ID="updatePnl" runat="server"> <ContentTemplate> <fieldset> <legend>Panel Title</legend>
<igcmbo:WebCombo ID="WebCombo1" runat="server" Version="4.00"> <ExpandEffects ShadowColor="LightGray" /> <Columns> <igtbl:UltraGridColumn> <header caption="Column0"> </header> </igtbl:UltraGridColumn> </Columns> <DropDownLayout Version="4.00"> <framestyle height="130px" width="325px"> </framestyle> </DropDownLayout> </igcmbo:WebCombo> <asp:Button ID="btnPrint" runat="server" OnClientClick="btnPrint_Click" Text="Imprimer" Width="133px" /> <!-- Code pour avoir le message de : chargement en cours --> <asp:UpdateProgress ID="siteUpdateProgress" runat="server" AssociatedUpdatePanelID="updatePnl" DisplayAfter="100" DynamicLayout="true"> <ProgressTemplate> <div class="Sample5PageUpdateProgress"> <asp:Image ID="ajaxLoadNotificationImage" runat="server" AlternateText="[image]" ImageUrl="~/images/ajax-loader.gif" /> <br /> <span style="color:Black">Chargement en cours... </span> </div> </ProgressTemplate> </asp:UpdateProgress> </fieldset> </ContentTemplate> </asp:UpdatePanel>
<ig:WebDialogWindow ID="wdwMessage" runat="server" Height="300px" Width="400px" WindowState="Hidden"> </ig:WebDialogWindow>
</form></body></html>
I copied those codes to a website and it seemed to work without problems. If I removed WindowState="Hidden" from dialog, then dialog appeared as well. Though, I did not have css files used by your page. Try to temporary remove those link and test behavior without external custom css classes.
I found the problem and i dont know if its normal!
If i move the WebDialogWindow before the declaration of WebCombo the page work!
