I have a report that could potentially have up to 1.2 million records. I have implemented custom paging and only query 500 records at the time. It all seems to work fine however the call for the first page for the very first 500 records the app takes around 1.5 min since it pulls the first 500 records from the complex query plus it also does a count(*) for the whole query (1.2 million) in order to calculate the number of pages (That's the only reason why I count all the possible rows returned).
So as you can see it executes the query (in the same stored procedure) twice for the first page.
I was thinking that I could get the 500 records and then with javascript execute a web method and get the count asynchronously. This would involve setting the page count with javascript so the WebNav control also works (otherwise it doesn't fire a postback).
So, how can I change the paging settings on the client side?
Thanks!
Hi ureyes84,
It has been a while since your post but in case you still need help I would be glad to assist you.
The UltraWebGrid paging (including settings) need to be set server-side as these values are needed to calculate how much data is to be sent to the client. More information on that subject can be found in the following discussion:
http://forums.infragistics.com/forums/p/20636/74416.aspx
Please contact me if you have any questions.
Best Regards,Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
