I have set a WebDropDown control to disabled for some purpose.
E.g. wdpOptions.Enabled = false;
On disabled, the WebDropDown control is mapping to this image (/ig_res/Default/images/igdd_DropDownButtonDisabled.png) which is not available.
However, if I enabled, it works fine as the WebDropDown control is mapping to this image (/ig_res/Default/images/igdd_DropDownButtonHover.png) which is available.
Please advice how to get this image (igdd_DropDownButtonDisabled.png).
I am using version 10.3 , which I installed on 17-Oct-2010 ,Is there any release after that.I sam also missing with igdd_DropDownButtonDisabled.png.
Hi Chetan,
Do you use 10.1, or 10.2 or 10.3? You can grab the latest one that's posted on the website and it will work
Angel
Hey Angel,
Is the Service pack already released for this fix?
If Yes, what is the Version?
Thanks in Advance
~ Chetan
This is related to a development issue that was fixed recently, and if you upgrade the assemblies with the latest version it should be gone & working properly.
Thank you,
