I am attempting to delete a child row on a hierarchical Data Grid but i keep get an error: Requested record cannot be found by key. I have no problems with insert,update,or delete on parent and no problems with update or insert on child.. just delete. I am programatically setting the data source. I have supplied the source code for this page. I have run out of ideas... need help
BLOCKED SCRIPT
function DeleteChildRows() { var grid = $find('whdgRatings'); var gridRows = grid.get_gridView().get_rows(); var selectedRows; var row; var childGrid;
for (var j = 0; j < gridRows.get_length(); j++) { row = gridRows.get_row(j);
childGrid = row.get_rowIslands()[0]; selectedRows = childGrid.get_behaviors().get_selection().get_selectedRows();
if (selectedRows.get_length() > 0) {
for (var i = selectedRows.get_length() - 1; i >= 0; i--) {
row = selectedRows.getItem(i); gridRows.remove(row); } // Single Select allowed break; }
}function DeleteRow() { var grid = $find('whdgRatings');
var selectedRows = grid.get_gridView().get_behaviors().get_selection().get_selectedRows();
for (var i = selectedRows.get_length() - 1; i >= 0; i--) { var row = selectedRows.getItem(i); gridRows.remove(row); }}
Grid:
<ig:WebHierarchicalDataGrid ID="whdgRatings" runat="server" AutoGenerateColumns="False" DataKeyFields="RATING_SET_ID" DataMember="RATINGS" Key="RATINGS" AutoGenerateBands="False" InitialDataBindDepth="2" onrowadding="whdgRatings_RowAdding" onrowsdeleting="whdgRatings_RowsDeleting" onrowupdating="whdgRatings_RowUpdating" ItemCssClass="WebDataGridItemCssClass"> <Bands> <ig:Band AutoGenerateColumns="False" DataKeyFields="RATING_SET_ID,RANK" DataMember="RATING_SET" Key="RATING_SET_ID,RANK" onrowadding="whdgRatingSet_RowAdding" onrowsdeleting="whdgRatingSet_RowsDeleting" onrowupdating="whdgRatingSet_RowUpdating" OnRowDeleted="whdgRatingSet_OnRowDeleted" ItemCssClass="WebDataGridItemCssClass" Width="575px" > <Columns> <ig:TemplateDataField Key="Delete" Width="30px" > <ItemTemplate> <asp:ImageButton runat="server" ID="DeleteItem" AlternateText="Delete" ImageUrl="/Resources/images/icons/redX.gif" OnClientClick="DeleteChildRows(); return false;" /> </ItemTemplate> </ig:TemplateDataField> <ig:BoundDataField DataFieldName="RATING_SET_ID" DataType="System.Int32" Hidden="True" Key="RATING_SET_ID"> <Header Text="BoundColumn_0" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="RANK" DataType="System.Int32" Key="RANK" Width="75px"> <Header Text="Rank" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="NAME" DataType="System.String" Key="NAME" Width="300px"> <Header Text="Name" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="RATING_VALUE" DataType="System.Int32" Key="RATING_VALUE" Width="100px"> <Header Text="Rating Value" /> </ig:BoundDataField> </Columns> <Behaviors> <ig:EditingCore EnableInheritance="True"> <Behaviors> <ig:CellEditing> <ColumnSettings> <ig:EditingColumnSetting ColumnKey="RANK" EditorID="nepSpinControl" ReadOnly="True" /> <ig:EditingColumnSetting ColumnKey="NAME" /> <ig:EditingColumnSetting ColumnKey="RATING_VALUE" EditorID="nepTypedNumeric" /> </ColumnSettings> <EditModeActions EnableOnActive="True" MouseClick="Single" /> </ig:CellEditing> <ig:RowAdding Alignment="Top"> <ColumnSettings> <ig:RowAddingColumnSetting ColumnKey="RANK" EditorID="nepSpinControl" /> <ig:RowAddingColumnSetting ColumnKey="NAME" /> <ig:RowAddingColumnSetting ColumnKey="RATING_VALUE" EditorID="nepTypedNumeric" /> </ColumnSettings> <AddNewRowClientEvents ExitingEditMode="whdgRatings_RowAdding_ExitingEditMode" EnteredEditMode="whdgRatings_RowAdding_EnteredEditMode" /> <EditModeActions EnableOnActive="True" MouseClick="Single" /> </ig:RowAdding> <ig:RowDeleting Enabled="true" /> </Behaviors> </ig:EditingCore> <ig:Sorting> </ig:Sorting> </Behaviors> </ig:Band> </Bands> <ClientEvents AJAXResponse="whdgRatings_ContainerGrid_AJAXResponse" /> <EditorProviders> <ig:DropDownProvider ID="ddpYesNoSelection"> <EditorControl DropDownContainerMaxHeight="200px" EnableAnimations="False" EnableDropDownAsChild="False" > <Items> <ig:DropDownItem Selected="False" Text="Yes" Value="Y"> </ig:DropDownItem> <ig:DropDownItem Selected="False" Text="No" Value="N"> </ig:DropDownItem> </Items> </EditorControl> </ig:DropDownProvider> <ig:NumericEditorProvider ID="nepSpinControl"> <EditorControl MaxDecimalPlaces="0" MaxValue="1000" MinValue="0" > <Buttons SpinButtonsDisplay="OnRight" SpinDelay="100"> </Buttons> </EditorControl> </ig:NumericEditorProvider> <ig:NumericEditorProvider ID="nepTypedNumeric"> <EditorControl MaxDecimalPlaces="0" MinValue="0" > </EditorControl> </ig:NumericEditorProvider> </EditorProviders> <Columns> <ig:TemplateDataField Key="Delete" Width="30px" > <ItemTemplate> <asp:ImageButton runat="server" ID="DeleteItem" AlternateText="Delete" ImageUrl="/Resources/images/icons/redX.gif" OnClientClick="DeleteRow(); return false;" /> </ItemTemplate> </ig:TemplateDataField> <ig:BoundDataField DataFieldName="RATING_SET_ID" DataType="System.Int32" Hidden="True" Key="RATING_SET_ID" > <Header Text="BoundColumn_0" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="DESCRIPTION" DataType="System.String" Key="DESCRIPTION" Width="400px"> <Header Text="Description" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="USES_SCORING" DataType="System.String" Key="USES_SCORING" Width="150px"> <Header Text="Uses Scoring?" /> </ig:BoundDataField> </Columns> <ErrorTemplate> <div>Here</div> </ErrorTemplate> <Behaviors> <ig:Activation Enabled="true"> </ig:Activation> <ig:Sorting> </ig:Sorting> <ig:Selection CellClickAction="Row" RowSelectType="Single"> </ig:Selection> <ig:EditingCore> <Behaviors> <ig:RowDeleting Enabled="true" /> <ig:CellEditing> <ColumnSettings> <ig:EditingColumnSetting ColumnKey="DESCRIPTION" /> <ig:EditingColumnSetting ColumnKey="USES_SCORING" EditorID="ddpYesNoSelection" /> </ColumnSettings> <EditModeActions EnableOnActive="True" MouseClick="Single" /> </ig:CellEditing> <ig:RowAdding Alignment="Top"> <ColumnSettings> <ig:RowAddingColumnSetting ColumnKey="DESCRIPTION" /> <ig:RowAddingColumnSetting ColumnKey="USES_SCORING" EditorID="ddpYesNoSelection" /> </ColumnSettings> <EditModeActions EnableOnActive="True" MouseClick="Single" /> </ig:RowAdding> </Behaviors> </ig:EditingCore> </Behaviors> </ig:WebHierarchicalDataGrid>
Code Behind:
protected void Page_OnLoad(object sender, EventArgs e) {
whdgRatings.DataSource = _db.GetRatings(); if (!this.IsPostBack) {// Sorting behavior = this.whdgRatings.Behaviors.Sorting; // behavior.SortedColumns.Add(this.whdgRatings.Columns["DESCRIPTION"], // Infragistics.Web.UI.SortDirection.Ascending); } }
#region Parent Events protected void whdgRatings_RowAdding(object sender, RowAddingEventArgs e) { int ratingSetId; try { ratingSetId = _db.InsertRating(e.Values["DESCRIPTION"].ToString(), e.Values["USES_SCORING"].ToString());
e.Values["RATING_SET_ID"] = ratingSetId; } catch (System.Exception ie) { ContainerGrid grid = (ContainerGrid)sender;
grid.GridResponse.Message = ie.Message; } }
protected void whdgRatings_RowsDeleting(object sender, RowDeletingEventArgs e) { try { object[] dataKey = e.Row.DataKey;
_db.DeleteRating(Convert.ToInt32 ( dataKey[0] ) ); } catch (System.Exception ie) { ContainerGrid grid = (ContainerGrid)sender;
grid.GridResponse.Message = ie.Message + "<br/>" + ie.InnerException.Message; } }
protected void whdgRatings_RowUpdating(object sender, RowUpdatingEventArgs e) { try { object[] dataKey = e.Row.DataKey;
_db.UpdateRating(Convert.ToInt32 ( e.Values["RATING_SET_ID"] ), e.Values["DESCRIPTION"].ToString(), e.Values["USES_SCORING"].ToString());
grid.GridResponse.Message = ie.Message; } } #endregion
#region Child Events protected void whdgRatingSet_RowAdding(object sender, RowAddingEventArgs e) { ContainerGrid grid = sender as ContainerGrid; object [] keyId = grid.ParentRow.DataKey; int ratingSetId; try { ratingSetId = Convert.ToInt32(keyId[0]);
_db.InsertRatingSet(ratingSetId, Convert.ToInt32(e.Values["RANK"]), e.Values["NAME"].ToString(), Convert.ToDouble(e.Values["RATING_VALUE"])); e.Values["RATING_SET_ID"] = ratingSetId;
} catch (System.Exception ie) { grid.GridResponse.Message = ie.Message; } }
protected void whdgRatingSet_OnRowDeleted(object sender, RowDeletedEventArgs e) { } protected void whdgRatingSet_RowsDeleting(object sender, RowDeletingEventArgs e) { System.Data.DataRowView row; ContainerGrid grid;
row = e.Row.DataItem as System.Data.DataRowView;
try { _db.DeleteRatingSet(Convert.ToInt32(row["RATING_SET_ID"]), Convert.ToInt32(row["RANK"]));
grid.Rows.RemoveAt(e.Row.Index); } catch (System.Exception ie) {
protected void whdgRatingSet_RowUpdating(object sender, RowUpdatingEventArgs e) {
try { _db.UpdateRatingSet(Convert.ToInt32(e.Values["RATING_SET_ID"]), Convert.ToInt32(e.Values["RANK"]), e.Values["NAME"].ToString(), Convert.ToDouble(e.Values["RATING_VALUE"])); } catch (System.Exception ie) { ContainerGrid grid = (ContainerGrid) sender;
DataSource:
That was the problem.... thank you sir.
Hello,The problem is in your DeleteChildRows function. When you remove a row from a child grid, you must get a reference to its row collection. Try this: for (var j = 0; j < gridRows.get_length(); j++) { row = gridRows.get_row(j); childGrid = row.get_rowIslands()[0]; childGridRows = childGrid.get_rows(); selectedRows = childGrid.get_behaviors().get_selection().get_selectedRows(); if (selectedRows.get_length() > 0) { for (var i = selectedRows.get_length() - 1; i >= 0; i--) { row = selectedRows.getItem(i); childGridRows.remove(row); } // Single Select allowed break; }Regards,Nikolai DImitrov
