I have two trees. Right tree is a source of nodes for the left tree. When I drag a node from right tree to the left one it get's added to that tree. I have a async callback set on node click and when I click on the newly dropped node I get an error "[FormatException]: Input string was not in a correct format".
Is there a solution to this problem as this is an essencial to our product?
Sample source (without ig_res folder) attached.
Bartek
Hello mayanksingh,
Please let me know if you need further assistance with your question and you are not resolved your error.
mayanksingh said:So can u please suggest me how can i remove this error ...i am sending you the my project files and and screen shot of my error
In order to help you I need more information about your scenario:
- What version of the controls you are using and what build is that version (default build for version 10.3 – RTM - is 10.3.20103.1013)?
- What is your Visual Studio version and what browser you used to test your project?
- Where did you upload your project files and screenshot?
If you want to upload files and send them for testing, you may use your profile (“My Files > Add File”) and attach them from there, or use “Options” tab (located on top of response panel near “Compose” tab). The files are better to be in archived (.zip) format.
Thank you for choosing Infragistics.
HI ,I am using two WebdataTrees and i want to drag node from one tree and drop that node to another tree ..that working on client side but i have to save that in database so ..need to implement on server side ..but while dragging on node of webtree 1 and droping to another tree it will give following error Error: Object doesn't support this property or methodSo can u please suggest me how can i remove this error ...i am sending you the my project files and and screen shot of my error Please suggest me the appropriate solution for this.
an public bug 58734 was reported about this problem. It is now fixed. Work with developer support to get more info about the date when it will be released.
Lubomir
