I have this..
<ig:WebDatePicker ID="WebDatePicker1" runat="server" DisplayModeFormat="g" EditModeFormat="g" StyleSetName="Default" StyleSetPath="ig_res"> <ClientSideEvents CalendarClosed="CalClose1" /> </ig:WebDatePicker>
so when the calendarClosed event is hit I want it to run this function.
function CalClose1() if icount1 =0 then icount1=1 webdatepicker1.value = webdatepicker1.value & " 12:00:00 AM" end if end function
I get an error from your javascript saying CalClose1 must be a function..
someone wanna tell me what I have done wrong?
entire script below
<script type="text/script" language="vbscript"> dim icount1 dim icount2 function CalClose1() if icount1 =0 then icount1=1 webdatepicker1.value = webdatepicker1.value & " 12:00:00 AM" end if end function function CalClose2() if icount2 =0 then icount2=1 webdatepicker2.value = webdatepicker2.value & " 11:59:59 PM" end if end function </script>
thanks. that worked.. your date code was much more elgant then mine.. (you can tell I don't do much javascript)
You need to introduce a delay to set the time correctly. For example:
var date_val;
function CalendarClosed(sender, eventArgs) { var dt = eventArgs.get_value(); date_val = dt.format("MM/dd/yyyy") +" 00:01 AM"; setTimeout("UpdateDate()", 500); } function UpdateDate() { if (date_val != null && date_val != "") { var wdp = $find("<%=WebDatePicker1.ClientID %>"); wdp.set_text(date_val); } }
Valerie
so here is the complete function..
function dp1_ft(sender, eventArgs) { if (dp1 == false) { dp1 = true; var dp = $find("<%=WebDatePicker1.ClientID%>"); if (!dp) { return; } else { var new_val = eventArgs.get_value(); var replacementDate = new Date() replacementDate = (new_val.getMonth() + 1) + '/' + new_val.getDate() + '/' + new_val.getFullYear() + ' 12:01 AM'; // alert('original value=' + new_val); // alert('original text=' + new_val.toLocaleString()); dp.set_text(replacementDate.toLocaleString()); dp.set_value(replacementDate); // alert(' replacement value=' + dp.get_value()); // alert(' replacement text=' + dp.get_text()); } } }
I noticed when the alerts were not commented that the control would show the correct value. but as soon as I would click the okay on the alert box it would go back to what was there. example:
dropdown calendar select November 10
alerts in get_value statements show.. 11/10/2010 12:01 AM
but calendar control still shows 11/10/2010 12:00 AM
I have tried changing the time value to something else like 2AM, but it still doesn't change.
okay, so I can now get the value. I am trying to set the value but it is not working.
dropdown calendar, select any day, returns m/d/y 12:00 AM
I want it to return m/d/y 00:01 AM
My code is below..
the other thing is this should only do this 1 time, hence the boolean compare
var dp1 = new Boolean(); function dp1_ft(sender, eventArgs) { if (dp1 == false) { dp1 = true; var dp = $find("<%=WebDatePicker1.ClientID%>"); if (!dp) { return; } else { var new_val = eventArgs.get_value(); var replacementDate = new Date() replacementDate = (new_val.getMonth() + 1) + '/' + new_val.getDate() + '/' + new_val.getFullYear() + ' 00:01 AM'; alert('newvalue=' + replacementDate); dp.set_text(replacementDate); dp.set_value(replacementDate); alert(' newvalue=' + dp.get_value()); } } }
ah.. thank you very much..
that is working just dandy.
