Can a Menu Item be disabled through Javascript?
When I try to use the GetItems() function of the WebData Menu I get: Object doesn't support this property or method.
I believe this functionality existed in 9.2.
Here is the code I'm using. This worked in a 9.2 project:
var
items = menu.getItems();
An example of the Javascript that will work would be appreciated.
Thanks in advance.
Thank you, I was looking for it all over the internet. May be you could add it to the documentation as well.
Thank you for the answer and it's quickness. It worked exactly as I wanted. I'm not sure I would have gotten there from the 9.2 code I was given so your assistance was very valuable.
Hello Kishore,
A MenuItem can be disabled with javascript. For example, if you would like to disable the first root item you can do it like this:
var menu = $find("<%=WebDataMenu1.ClientID %>");
menu.getItems().getItem(0).set_enabled(false);
Hope this helps.
Lyuba
Developer Support Engineer
www.infragistics.com/support
