Hi Lyuba,
I have a WHDG with 3 levels of data. I keep getting a javascript error message every time I try to sort the data.
=================================================================Stop running this script?
A script on this page is causing Internet Explorer to run slowly. If it continues to run, your computer may become unresponsive.=================================================================
My dataset has 3 data tables with data relations set. 1st level data table - 8 rows2nd level data table - 60 rows3rd level data table - 120 rows
I have such small amount of data but the WHDG does not work. Any workaround to resolve this issue. I would appreciate your response!
Cool...This solves the problem for now. Thank you Lyuba.
I had another question related to WHDG that I posted in the forum but didnt see any response. I would appreciate if you could look into it. A case for the same is also opened and the case number is CAS-55446.
http://community.infragistics.com/forums/p/47256/256831.aspx#256831
You can try setting the property ScriptMode of the script manager to Release. If this doesn’t help would you attach me a sample that I can use for reproducing your issue?
Lyuba
Developer Support Engineer
www.infragistics.com/support
