1360
How to disable Scrollbars on a WebDataTree?
I need to be able to supress the scrollbars that appear in a WebDataTree of fixed dimension. I don't mind if the supression is via server-side or client-side code or via declarations in the .ASPX file. I also do not mind that by removing the scrollbar the text is truncated, this is by design - the tree in question is a small preview of data selected from another control. The tooltip will give the full data if an item is hovered over.
Kind regards Paul
VS 2010
IG 10.3 WebDataTree
CLR 4.0
