Hi, iam use the Webdatagrid with a custom pager. i can paging an jump to each page.first when i run the page i take paging on and
WebDataGrid1.Behaviors.Paging.PageSize =
30but i have above the grid a textbox where i can enter a query . when someone enter a query text i want paging off (i tryed with WebDataGrid1.Behaviors.Paging.Enabled = False)
but the grid displays me always the first entry from the current page.(an not my query. the datatable has the correct search sql statement and returns me the correct result set.is there something iam missing?
I created a support ticket on your behalf. You can attach your files there.
Lyuba
Developer Support Engineer
www.infragistics.com/support
hi, can i sent the source direct to you, because i don't want it public.the problem is still there..
Let us know if you still need help with this.
Hello Martin,
You are using the correct way for turning off the paginatio. Would you attach your aspx and vb pages, in order to get more familiar with your configuration?
