589
How to get the Columncount value and set the column width
We're using the Infragistics 2010.3 ASP.NET version controls and having issues in accessing the column properties (such as column count and setting a column width).
We're using a datasource to build the grid data and attaching the datatable to the grid.
In the ASPX page, the grid is declared as below
<ig:WebDataGrid ID="UGData" runat="server" Height="350px" Width="767px" />
In the Code Behind page, the below snippet attaches the databtable to the grid
        Dim dt As New DataTable()
        UGData.AutoGenerateColumns = True
        dt.Columns.Add("Column 1", Type.[GetType]("System.Double"))
        dt.Columns.Add("Column 2")
        dt.Columns.Add("Column 3")
        Dim dr As DataRow = dt.NewRow()
        For i As Integer = 1 To 5000
            dr = dt.NewRow()
            dr(0) = i
            dr(1) = DateTime.Today.AddDays(i)
            dr(2) = "Test " & i.ToString()
            dr(3) = (i Mod 2 = 0)
            dt.Rows.Add(dr)
        Next
        UGData.DataSource = dt
        UGData.DataBind()
For some reason, the 'UGData.Columncount' property always returns 0. Also, the I can't set the column width using 'UGData.Columns(0).Width = Unit.Pixel(100)'
whats wrong?
