160
Can't move Column in Trial version?
Is column moving disabled in the trial version of the WHDG? I have the behavior enabled and I am able to click and move the column header but it never moves the column.  There is also a circle with a slash in it on the cursor marking it as broken or disabled.
Thanks Much
  • 33839
    Suggested Answer
    Hi johaunarei ,
    Column Moving is not officially supported in the WebHierarchicalDataGrid yet.  It is planned for the next release.  It sounds like you have grouping on.  The Column Moving behavior will not work at all if that is on.  It is only starting a group by drag operation.  If you do not have the Group By Area visible, then it should be allowable to move columns in a row island.
    regards,
    David Young
