I have a hierarchical grid with 6 levels. When I export the grid to Excel I get no errors reported but:
a) the process of exporting is very slow (30s to export a simple grid with fewer then 30 rows of data, and thats on a v. fast system: quad-core @3.4Ghz, 8Gb RAM, 320GB SSD, 64-bit Win7 Ultimate). Totally unacceptable performance given that real-world data could have hundreds of rows.
b) not all of the data is exported - the final (deepest) level of the hierarchy is missing in Excel although it is displayed in the grid. I understand that Excel has a nesting limit of 8 for data outlining so we are well within that. Again this is unacceptable.
I ensure that just prior to export the grid is fully expanded and showing all of the data. My code to perform the export is: (where WEX is the ID of the WebExcelExporter).
WEX.ExportMode = Infragistics.Web.UI.GridControls.
ExportMode.Download;WEX.DownloadName = "CapitalCostAnalysis";WEX.Export(WHDG1); // WHDG1 is the Hierarchical Data Grid
Am I doing something wrong or is this another example of major flaws? I'm beginning to lose faith in this software; it seems buggy, inefficient (hierarchical grids are hopelessly slow to load) and poorly documented (many of the examples show trivial stuff but are of limited help for real-world situations where much more detail is required. Many methods and properties have no details giving a description of their intended use or function). Some of the code examples just don't work at all (in IE8).
Anyway, whinge over. Any ideas for the Excel export problem?
Pual Shearing
IG 10.3CLR 4.0VS 2010
Hi Mike
I have emailed support and posted an update in MyIG area requesting details of how to access the interim version with the bug fix. Please forward details ASAP - this is getting urgent.
Paul
Hello Paul,
Thank you for submitting your inquiry to the Infragistics ASP.Net Forums. I have opened a support request for this forum post so this behavior may be researched further. Please use the following link to log onto your account at Infragistics.Com:<https://ko.infragistics.com/Membership/MySupport.aspx>Once you are logged onto your account, go to My Support Activity to view the progress of this support request. I will send you an update in the support request.Please let me know if you have any questions.Thank you.Sincerely,Mike D.Developer Support EngineerInfragisticswww.infragistics.com/support
