860
AddNewRow Problem
It appears that if you are editing a new row  then click on another row in the grid.  The new grid does not attempt to add row.  It seems that you must tab to the end of the row to get it to update.  Is there a way to override this behavior.
  • 12679
    Suggested Answer
    Please refer this link : http://forums.infragistics.com/forums/p/34719/196424.aspx#196424
    <Behaviors>
         <ig:CellEditing>
           <CellEditingClientEvents
           ExitedEditMode="ExitedEditModeHandler"/>
          </ig:CellEditing>
     </Behaviors>
    The javascript needed to commit the changes is like this:
    <script type="text/javascript">
        function ExitedEditModeHandler(sender, args) {
            $find('<%=WebDataGrid1.ClientID %>')
           .get_behaviors().get_editingCore().commit();
        } </script>
    In order this code to work you will need to handle RowUpdated server-side event.
    Hope this helps
