If i have changed the dropDown1 value then
is coming. problem is to refresh the infragistics menu, can you tell me how to resolve this problem?
<table style="margin-top: 7px; min-width: 800px;"> <tr> <td> <table runat="server" id="tblSearch"> <tr> <td> <asp:Label ID="lblSearch" runat="server" Text="Search By"></asp:Label> </td> <td> <ContentTemplate> <asp:DropDownList ID="dropDown1" runat="server" OnTextChanged="ValChange" AutoPostBack="true" Width="200px"> </td> <td> <asp:UpdatePanel ID="u2" runat="server"> <ContentTemplate> <asp:DropDownList ID="dd2" runat="server" Width="200px" AutoPostBack="True"> </asp:DropDownList> </ContentTemplate> <Triggers> <asp:AsyncPostBackTrigger ControlID="dropDown1" /> </Triggers> </asp:UpdatePanel> </td> <td> <asp:Button ID="btn1" Text="Go" ToolTip="Search" runat="server"> </asp:Button> </td> </tr> </table> </td> </tr> <tr> <td> <div> <asp:UpdatePanel ID="pnlGrid" runat="server"> <ContentTemplate> <ig:WebDataGrid ID="webGrid" runat="server" EnableDataViewState="True" AutoGenerateColumns="False" OnColumnMoved="webTableGrid_ColumnMoved" OnColumnResized="webTableGrid_ColumnResized"> <ClientEvents MouseDown="GridMouseDown" DoubleClick="OpenWindow" /> <Columns> </Columns> </ig:WebDataGrid> </ContentTemplate> <Triggers> <asp:AsyncPostBackTrigger ControlID="btn1" /> </Triggers> </asp:UpdatePanel> <ig:WebDataMenu ID="Menu" runat="server" IsContextMenu="true" BorderWidth="1" BorderColor="#CCCCCC"> <ClientEvents /> </ig:WebDataMenu> </div> </td> </tr></table>
With the current implementation the WebDataMenu can't work when it is rendered from within an update panel and is used as Context Menu. The best aproach would be to contact Developer support to open a case with feature request, and what I can do is to follow up with you here on that feature request is being processed.
i've just got the same problem.WebDataMenu in an updatePanel rise this error on clicking on a button
