370
Flasking at the first display
Hi, the grif is showed with a flash at the first display if is used javascript to show & hide.
So, I use the property style="display:none" to create a tab structure from javasctript, but on the first display, changing "none" in "block" is manifested this flash.
Have you seen this behaviour ? Do you have any solution ?
Thank you in advance!
Lidia
  • 49378
    Hi Lidia,
    It has been a while since your post, however in case you still need assistance I would be glad to help.
    I have investigated the described scenario but am so far unable to replicate the issue. In order to be able to investigate this further I would need a sample where the issue is reproducible.
    Please do not hesitate to contact me if you have any questions.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
