440
Editor control in Webhierarchichal grid
Hi
I'm new to Web hierarchichal grid. I want to bind the editor controls in web hierarchichal grid.
I achieved this functionality in wingrid. Below is the sample code.
private
void gridQuestions_InitializeRow(object sender, InitializeRowEventArgs e)
string fieldType = "";
ValueList editorsValueList = this.GetEditorsValueList();
int index = 0;
EmbeddableEditorBase editor = null;
if (e.Row.Band.Index == 0)
e.Row.Appearance.FontData.Bold =
DefaultableBoolean.True;
if (e.Row.Band.Index >= 1)
fieldType =
"Text Editor";
switch (e.Row.Cells["TYPE"].Value.ToString())
case "Text":
fieldType =
"Text Editor";
break;
case "YNA":
fieldType =
"Option Set Yes No";
break;
case "LAHD":
fieldType =
"Drop-down using ValueList";
break;
index = editorsValueList.FindStringExact(fieldType);
if (index >= 0)
editor = (
EmbeddableEditorBase)editorsValueList.ValueListItems[index].Tag;
e.Row.Cells[
"ANSWER"].Editor = editor;
e.Row.Cells[
"ANSWER"].Column.CellMultiLine = DefaultableBoolean.True;
Screenshot is attached.
I want to achieve this in Webhierarchicalgrid. Any help would be appreciated.
Sam
  • 230
    We are also trying to achieve a similar thing in UltraWebGrid and we are not able to. We need to bind different controls in different rows, in different bands, but they are all in the same column.
    Can any one help pls.
