I have a page that has 2 UltraWebGrids on it, an upper and lower. The grids themselves can vary in length, so the FrameStyle of each grid has been hard coded so users can look at one set of info in the upper and compare to the info in the lower.
I'm trying to figure out a way to make these frames' height size dynamically on page resize. Can anyone point me in the right direction?
Thanks.
Hello ThatGuy,
If you want to dynamically resize the grids when the window is resized, you will need to do a little javascript.
First, handle the body onload function.
then hook up the window.onresize() function.
Then resize the grid in the onresize function using the grid.resize(width,height) method.
I have provided you with a code snippet of all of this including a generic way to find the size of the window in different browsers. In the grid.resize() method, you will see that i set the width to the width of the window. If you dont want to do that, you can get the width of the grid by doint the following: parseInt(topGrid.MainGrid.style.width)
<body onload="OnLoad()">
function OnLoad() { window.onresize = WindowResized; }
function WindowResized() { var windowSize = GetWindowSize(); var topGrid = igtbl_getGridById("UltraWebGrid1"); topGrid.resize(windowSize.width, windowSize.height / 2); var bottomGrid = igtbl_getGridById("UltraWebGrid2"); bottomGrid.resize(windowSize.width, windowSize.height / 2); } function GetWindowSize() { var w = 0; var h = 0; //IE if (!window.innerWidth) { //strict mode if (!(document.documentElement.clientWidth == 0)) { w = document.documentElement.clientWidth; h = document.documentElement.clientHeight; } //quirks mode else { w = document.body.clientWidth; h = document.body.clientHeight; } } //w3c else { w = window.innerWidth; h = window.innerHeight; } return { width: w, height: h }; }
This should do the trick.
