20
Error Adding Image on Export
I'm trying to export a grid that has an image column to PDF.
I'm currently using the CellExporting Event to try add the image.
 protected void dExporter_CellExporting(object sender, DocumentCellExportingEventArgs e)
            if (!e.IsHeaderCell && !e.IsFooterCell && !e.IsSummaryCell)
                if (e.GridCell.Column.Key == "ImageUrl")
                    // Remove Html Tags
                    var url = e.GridCell.Text;
                    var startPos = url.IndexOf("\"") + 1;
                    var endPos = url.LastIndexOf("\"");
                    url = url.Substring(startPos, endPos - startPos);
                    e.ReportCell.AddImage(new Infragistics.Documents.Graphics.Image(url));
The issue I am having is that e.ReportCell is always null.
How do I initialize this so that I can format the ReportCell, or should I be trying to do this in a different way
