Is it possible to Merge Cells with PDF Document Export? If so, can you please post a sample code?
I am using Infragistics35.WebUI.UltraWebGrid.DocumentExport.v10.1
Thanks in advance.
Here is the print screen that I have and would like to merge contents of first column.
did you resolve your issue?
yes it is possible to merge cells. Please take a look at the following links: https://ko.infragistics.com/community/forums/f/retired-products-and-controls/66085/grouping-sample-doesn-t-works-well#66085
https://ko.infragistics.com/help/aspnet/infragistics.webui.documents.reports~infragistics.documents.reports.report.text.itext~addmergecode
I hope it will help
